Pontiac ram air 5
1972ho
Pontiac ram air 5
Post by 1972ho » Wed Jul 18, 2018 10:59 pm
Did this engine ever get put in a street car and if it did what car had it.looks like some of it was copied from a ford 427 tunnel port engine parts of the head and intake for sure.And from the article the thing over 500 hp in factory trim anyone know how much it made all raced up.
DrillDawg
Re: Pontiac ram air 5
Post by DrillDawg » Wed Jul 18, 2018 11:20 pm
It's states that it was never put in a factory car, but I'm sure the GTO and trans am would of got it.
BORN RIGHT THE FIRST TIME
Stan Weiss
Post by Stan Weiss » Thu Jul 19, 2018 12:21 am
There are a few companies that are producing modern verses of the RAV head.
Stan
Stan Weiss / World Wide Enterprises
Do you use engine simulation software that uses cylinder head flow files?
We have a package of more than 3000 DFW or FLW Files
mag2555
Post by mag2555 » Thu Jul 19, 2018 6:32 am
The 400 CID motors where never installed in a production car Stan, but the 366 CID version did make it into a few races in the Trams am series back then until the rules changed and the CID limit of 303 , and then those big tunnel port heads where too big for the low deck 303 motors to make power ( sounds like a Ford motor I know of) and Pontiac had to go back to the RA4 production heads with port work.
Here's a new version of the RA5 heads going on a 540 cid motor, it should make a easy 700 hp in its owners 69 GTO judge.
plovett
Post by plovett » Thu Jul 19, 2018 7:15 am
This quote cracks me up, "....the slow speed of the intake charge tends to moderate some of the camshaft duration, and the engine manages to have more torque than one might expect."
Cool engine, cool article. Thanks for sharing.
JMO,
paulie
mag2555
Post by mag2555 » Thu Jul 19, 2018 7:48 am
Yes, the good Dr Philp Bauman needs to stick with what he knows about Blood pressure , not air flow velocity vs Cam duration!
Frankshaft
Post by Frankshaft » Thu Jul 19, 2018 9:16 am
JMO,
paulie
He pretty much has it bass ackwards.
427dart
Post by 427dart » Thu Jul 19, 2018 9:47 am
I believe Royal Pontiac drag tested one in a 1969 Firebird and after a few runs they spun some rod bearings. I have that magazine in my collection.
This was still in the days of bigger has to be better as in huge round ports! Think those heads would have worked better on the 428/455.
The RA V was an over the counter item mostly in parts I believe and in very limited quantity.
ClassicComp
Post by ClassicComp » Thu Jul 19, 2018 9:42 pm
I have a few pics of them on "the Farmers" funny car.
results speak for themselves
BobF
tjs44
Post by tjs44 » Thu Jul 19, 2018 11:40 pm
I have been building RAV engines for about the last 15 or so years.The factory built 25 complete 303 SCCA short deck V engines but we're not enough to be allowed to run.The did build a few 366 NASCAR engines for the 71-72 season in firebirds,Buck Baker drove one.They built about 100 400 engines that were sold over the counter.They also had some engineering alu blocks,I have owned 2 of them along with 2 of the short deck SCCA engines.My current engine is a complete running 366 NASCAR engine for my 69 firebird.Engineering also built some 4 in stroke and some 4.21 stroke cranks to build a 428 or 455 V engine.And yes the heads were copied from the Ford TP engines.In fact a V intake can be fabed from. Ford TP intake of which I have 2 of them at this time.My 366 engine was just put on my run stand today as it was pulled from the bird to run a 455 for a track car.The V engine was too valuable to take a chance on the race track.Tom
1972ho
Post by 1972ho » Fri Jul 20, 2018 12:47 am
Has anyone ever dynoed one of the engine per the article spec with the .530 lift cam and 400 cid.
Jeff Lee
Post by Jeff Lee » Fri Jul 20, 2018 2:34 am
Lynn & Stacy McCarty build the new RAV Heads.
https://www.hotrod.com/articles/hppp-12 ... r-v-heads/
NHRA SS/H
1970 AMX
390 4-speed
Advanced Clutches
Red Line Racing Cams
midnightbluS10
Post by midnightbluS10 » Fri Jul 20, 2018 3:12 am
Why would a medical doctor be writing about cars? You sure it wasn't a PhD? There's quite a difference.
JC - Precision Guesswork & Expert Up Arrow Manipulation
mag2555
Post by mag2555 » Fri Jul 20, 2018 6:37 am
I know, but if he does or did have a phd he needs to go back to class and review some things!
It was said that back then the 400 cid V motor was making 375 hp as installed in the 69 test car from 1/4 mile times and it sounds about right for those slow flowing heads and the small .530" lift they had with that Cam!
Turbo231
Post by Turbo231 » Fri Jul 20, 2018 10:37 am
Just read the article. That's an awesome engine. No telling what the Pontiac engineers could have done back then if they hadn't killed the program. Those heads were just waiting for the 455. It would have stepped up the ante for everyone.
