Pro Stock Pontica Heads #427 for BBC Valve Train System
star393
Post by star393 » Sun Oct 26, 2008 11:41 pm
These heads came in many versions over its history 18 degree heads and one of them versions was finished head made without push rod holes in head. The idea was to let the engine builder ie( pro stocker) move the intake push rod over past the intake wall and do alot of porting on intake without needing to weld up the intake wall were the push rod use to be drilled thur part of the intake wall on previous versions. I have a set of these heads and am looking forward to using them new in the box. I have quite abit of valve train parts an i am in need of information on what intake rocker stand jesel or t&d to use here as a offset of appox. 0.500 is needed to put push rod outside the wall. I want to retain this feature of the head and not drill into the side of the intake wall and for future porting on bigger motors.
The body of a .500 offset is about 1.400 to 1.625 depending on , whats used so thats a whole diff. stand for the intake. Exhaust iam leaving alone. Jesel and T&D are not to willing to offer info on there sizes. so its hunt and peck or blow 2000.00 to them and let them outfit heads with valve train, not in my forcast thats for sure. So any infor from anybody that can advise me on part numbers of set up would be very helpful.
Douglas
SMITHBERGRACING
Post by SMITHBERGRACING » Tue Oct 28, 2008 10:33 am
I know this forum is full of knowledge! Maybe Darin Morgan or others could help you with this since it is an older Pro Stock head. I've tried looking for this info in the past myself and Jesel or T&D not wanting to let their info out. I hope someone can chime in.
bigjoe1
Show Guest
Show Guest
old prostock heads
Post by bigjoe1 » Tue Oct 28, 2008 6:55 pm
Here is a very sad story-- About 15 years ago, someone I knew bought some older PS takeoffs for 10,000 dollars. He put them on his 468 bracket car and it SLOWED down a half second. After about a year later and 10,000 more dollars for a Lenco trans and clutch setup, He was going a tiny( one tenth) faster than he started out. I dont know what your going to do with these heads, but the total engine combo is very important.
JOE SHERMAN RACING
Post by 1989TransAm » Tue Oct 28, 2008 7:00 pm
$20,000 for a tenth of a second. That is a sad story. I bet the $20,000 would have been put to much better use in his hindsight.
star393
my combo
Post by star393 » Wed Oct 29, 2008 1:03 am
3200 # chevelle 64 ss
538 dana 4 link 25.5 chassis
rpm area 7000 thur 9000 541 BBC 14.4.1 no power adders .840 roller at 302 @ .050 385 seat 960 open
4 speed car 302 first clutchless liberty sinder iron 11" clutch
sheetmetal intake dual quads 850,s
ill be doing bowl work port matching and 1.88 exh and possible 2.300 intake what ever i can squeeze in 4.375 hole with eyebrowing block
running 1.94 and 2.300 in iron 990 heads now.
$um Toy
Post by $um Toy » Wed Oct 29, 2008 8:14 am
From what you said about your combination, you don't have a lot of bore to work with so getting the flow you need is going to be difficult. Also 9000 RPM with a 4.5" stroke is pushing it, you better have some GOOD parts, and an oiling system up to the task.
revolutionary
Post by revolutionary » Wed Oct 29, 2008 8:32 am
You just need to call Jesel or T&D directly to get the part numbers. IMO those heads are still way too big for a 540 inch engine. You'll want to shrink the runners down and into an oval shape to get them working right for you. Also you'll want dual dominators not 850s. My employee and his dad run those on a 615BBC with pretty similar cam in a nitrous engine and they do pretty well but they are definitely big.
Daryl
Revolutionary Performance and Machine
star393
Post by star393 » Wed Oct 29, 2008 5:12 pm
I sure do push it and break em too.
$um Toy wrote:From what you said about your combination, you don't have a lot of bore to work with so getting the flow you need is going to be difficult. Also 9000 RPM with a 4.5" stroke is pushing it, you better have some GOOD parts, and an oiling system up to the task.
Sure do been doing this for 42 years and a 25 year vacation
454,s 10,500 out of the water
396 402 bury it.
283,s 327 sbc way past a 10,000 tac,
and not just anybody can do that either so yes its impossible but yes it is done. Good parts and alot of OEM parts too properly prep ed.
And the most important part FASTENERS and the how too.
Us old guys ha ha can make power without a credit card
star393
pro stock head
Post by star393 » Wed Oct 29, 2008 5:19 pm
Jesl and T&D are keeping there info top secert unless you give them a blank check and send them the heads. So if the infor is out there type away.
star393
Post by star393 » Mon Nov 17, 2008 12:32 am
please keep reading
want-a-be
Post by want-a-be » Mon Nov 17, 2008 1:10 am
I have some old Pontiac Pro Stock heads. I have them more for a keep sake then anything else. They are some old Butch Leal heads. I would be intrested in getting rid of them if they are what you're wanting. Not sure of the part number on them.
PM me if your intrested.
Don
Abbottracingheads
Post by Abbottracingheads » Mon Nov 17, 2008 9:32 am
What are the rules of the class you are running, or is this a bracket car? I could do you a set of RHS conventional heads that will blow the 990 chev. heads in the weeds.
trmnatr
Post by trmnatr » Mon Nov 17, 2008 11:19 am
star393 wrote:I sure do push it and break em too.
396 402 bury it.
Not gonna fight with you, Serious question
If you can do all this stuff with stock parts,,,,,
1) Why dont you go race NHRA or IHRA Stock or Super Stock :lol:
2) Why dont you just stick with your 10,500rpm heads :?:
star393
Post by star393 » Tue Nov 18, 2008 8:06 pm
[quote="trmnatr"][quote="star393"]I sure do push it and break em too.
[quote="$um Toy"]From what you said about your combination, you don't have a lot of bore to work with so getting the flow you need is going to be difficult. Also 9000 RPM with a 4.5" stroke is pushing it, you better have some GOOD parts, and an oiling system up to the task.[/quote]
396 402 bury it.
Us old guys ha ha can make power without a credit card[/quote]
2) Why dont you just stick with your 10,500rpm heads :?:[/quote]
First of all i did prove that already in the 70,s running altered you know weight to cubic inches it was no fun i ran away with everything we didnot have great time slips like today. That was three diff. tracks.
I have been thinking of putting my sbc back together again just to prove a point. The 461 heads are gone but still have my turbo 292 heads they ran me to 10.98 @124 mph in my little 283CI motor yep 10500 valve float at 11,000 stock rods steel crank 2 bolt mains chevy forged pistons 56cc angled milled heads now you dont think for one min. that stock push rods were used do ya, trw oil pump and 10 quart pan. roller cam. The hours involved in preping a set of rods is endless, crank too and a over bal. bottom end. I would buy a 4340 set of rods next go around why push my luck with the old ones. The flat tappet cams advailable back then were fair and i ran 11.20,s with that and oem rockers so alot can be had when things are done right. My point in all this was to let people of today know that stock parts can be used if done right and a person can have fun and still go fast on a strict buget with oem parts. You dont have to spend alot of money and go fast people are losing the abilty to practice real mechcanics and thinking back to the basics. I call today the big candy store of speed get out your credit card and order and ask afew people for combo info and slap it all together, which is great but like math. get out the calulator and punch buttons and cant do it on paper with a pencil. It keeps everyone else rich and the poor , poorer with no real knowledge of what there really doing. And if you really have money order and engine put it in and go racing. Besides a motor is one thing hooking up that power to the ground is another, another area that is lost with people or racers, chassic and the function or making it all work. I sure wish i had 60 ft time slips from back then because i know i was running atleast 1.150 times, i run 1.245 now without even trying to tune my 4 link. Power adders wow go fast with a slow winding motor and enjoy but when it goes boom your done big time. And yes cast pistons can go fast to but watch out for them valves thats big trouble then. All the functions of all the internal parts on a high rpm motor have to be done right or it will never live. After the sbc came my BBC 454 closed chamber heads stock steel rods steel crank flat tappet cam forged pistons 2 bolt mains spun that to 9500 10,000 also 9.89 138 mph in a chevy 2 in 1974 . I had alot of work trying to keep a 4 speed in that car that thing was like a arrow off a cross bow.
Heads just make the thing breath valve train is the ticket to high RPM,s not heads, better heads equal more air and more power and better flame travel and quench. Heads today are just fantasic compaired to yesterday along with shaft rockers.
So here i go bla bla bla .
Douglas
new engine builder
Post by new engine builder » Tue Nov 18, 2008 8:49 pm
396 402 bury it.
Douglas
Stock steel rods?,stock steel crank? 9,500 10,000 rpms?
Flat tappet cam?
KA-BOOM!!!
I'm new to engine building but not this new. :lol:
