Gas ported pistons for street use
Todd H
Post by Todd H » Wed Sep 07, 2005 9:58 am
Would gas porting a set of pistons increase ring wear on a street engine? I'm looking at rebuilding my engine and doing some modifications and thought about gas porting. I don't want to have to tear it back down every year to replace rings etc. Anyone run this setup on a high mileage motor before? TIA Todd H
67RS502
Post by 67RS502 » Wed Sep 07, 2005 10:17 am
Would lateral gas ports work ok on the street? anyone tried that?
67 camaro
girly rollers on pumpgas:
62 Nova cruiser
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
SStrokerAce
Post by SStrokerAce » Wed Sep 07, 2005 3:43 pm
Lateral gas ports would be the only ones I would run on the street. Gas porting depends on the size of the rings and size of the bore. A larger ring doesn't need a gas port to help it seal nor does a small bore.
All depends though... some motors can't live without gas ports. The RM boys could chime in on that one I'm sure.
Bret
67RS502
Post by 67RS502 » Wed Sep 07, 2005 4:05 pm
SStrokerAce wrote: Gas porting depends on the size of the rings and size of the bore. A larger ring doesn't need a gas port to help it seal nor does a small bore.
Bret
Wouldnt low tension (small) rings work well with lat. gas ports?
67 camaro
62 Nova cruiser
224/224 HR cam
1.57 10.97 @ 121.2
Todd H
Post by Todd H » Wed Sep 07, 2005 4:37 pm
Can you elobrate on this more? Todd H
Ron C.
Post by Ron C. » Thu Sep 08, 2005 12:50 am
If this motor is going to see lot's of street miles then stick with a conventional ring combination. A big part of a rings job is to transfer heat from the piston to the cylinder wall. If you don't what to be changing rings more than once a year of high mileage street driving, don't go down that road.
Creekside Racing Ministry
John 14:6
Ron Clevenger
CSU Gas Dominator ProCharger nonintercooled
Top Eliminator West http://www.topeliminatorwest.net
Steve Morris http://www.stevemorrisengines.com
6.49@219mph (still tunning)
SupStk
Post by SupStk » Thu Sep 08, 2005 9:48 am
Unless I'm totally missing the point the reason for gas ports (lateral or otherwise) is to get combustion gas behind the rings on tight fit top rings. For normal street use I wouldn't consider that type of package advantagious or even desireable.
SStrokerAce
Post by SStrokerAce » Thu Sep 08, 2005 10:07 pm
Agreed, once you have carbon build up filling the ports they are pointless anyways. On a street motor this is very likely to happen.
Bret
