No offense, but the Dyno numbers sound a little off. I have seen the Edelbrock Pontiac head. It is "of poor design" to try to say it with respect.ClassKing wrote:What's all this noise.
My standard King Street 455:
240's @ .050 hyd roller
4.21 stroke
6.625 rod
10.4 Cr.
91 octane
600 lbs. ft. at 4000 rpm
621 hp at 5400 hp.
87 cc Edelbrock heads - my work.
RPM intake.
850 Speed Demon
No shaft rockers. No high ports.
You can do it.
www.PontiacEngines.com
1.3 ft/lb per inch out of that head would be good. Especially to make more peak torque at peak power than at peak torque. (over 600 ft lb at peak power). Did you dyno it yourself? Does the torque just completely flat line from 4000 to 5400?
I have never used, or worked on a set of the KRE heads, but if I was forced to build a Pontiac I would surely use KRE over Edelbrock for power.
I just can't imagine why they would still use that flat, horrible chamber like the stock head, then put seats in that are way too big for the valve so you have a giant flat shelf. You could always sink the valvejob .200 and make it come in.
