Has anyone done some back to back testing on gas ports vs no gas ports? Are there any formulas for the area behind the ring for a given bore size and ring width? What land to ring clearance should be used?
Any pitfalls I should know about?
Thanks for the help!
Gas ported rings
- New Member
Gas ported rings
If you always do what you have always done,you will always get what you always got.
Stock 1090,
I'm not able to answer all your questions but will supply information that i have. I didn't have a dyno at the time so my testing was by experiment at the track so the results could be skewed. When I was racing a 351C in SS/J, tried lots of ring combos. With normal ring lands (not tight) gas ports made no discernable difference. On ring lands that required lapping the rings to fit, my best results came with 8 gas ports and almost zero back clearance on .043 stainless top rings. These were latteral ports since top ports weren't legal. However the ring I eventually used was a stainless .031 dyke.
- New Member
Rich,
The zero gap rings I'm familar with seem to have an aggressive nature. There seems to be alot of radial tension and drag on the cylinder walls. Given the added wall pressure provided by the gas ports, wonder if it might create more problems than power? I'm curious now... let me know what you come up with.
- New Member
