nissan ppu240 engine rebuild lift truck help please
I have an old lift truck in the shop it has a nissan ppu240 6 cylinder engine the #2 cam bore is all messed up. Does anyone have any specs on all 4 cam housing bore sizes? What should the max. oil clearance be for the cam bearings? I might have to libe bore the #2 cam bore and see if a sleave can be put in or find a larger cam bearing
- New Member
Drifter,
Give me the model and SN of the truck. I work at a Nissan Lift Truck dealership and can hopefully get you the info you need.
Richscaz@hotmail.com
If you always do what you have always done,you will always get what you always got.
Drifter,
I found some specs so hopefully this is correct. The "P" code helped.
Nissan 3956cc P/PF.. Bore 86mm... Stroke 114mm
Bearing set # SH-951S
Standard Shaft Diameter
1> 1.9350
2> 1.9270
3> 1.9158
4> 1.9030
Housing Bore
1> 2.0660
2> 2.0580
3> 2.0460
4> 2.0340
According to the book the P40/PF engine also has the same specs.
1> 1.9350
2> 1.9270
3> 1.9158
4> 1.9030
Housing Bore
1> 2.0660
2> 2.0580
3> 2.0460
4> 2.0340
the funny part about it is it had stock cam brgs std size so this cam had like .012 oil clearance on all 4 jornals can you beleive that?And the engine had a rebuilder tag on it from 1989 i have no clue if the cam was put in in 1989 like that and how it ran.I only thing that i know is the guy that owns it now dosent know anything how it ran because he just bought it with a seized engine.And i was told its been like that for 1 year approx.It was just about out of oil when i got it and thats the story i was told the guys ran it out of oil.So it must have had very low oil pressure from the day it was rebuilt.
