Holley Heads
Holley Heads
Hi All,
I have picked up complete 383 SBC with Holley heads, and plan to pull it down to tickle it up some.
It will be used just for a genuine street deal with just the occasional run down the track for fun.
I dont know much about these heads but I do know they are only small on the port volume and are somewhat limited.
Are they a reasonable piece and flow okay for their size?
Can they picked up much on with a rework?
Will you gain much more port volume/cross section or are they limited?
Would like to make at least around 450 ft/lbs and 450hp (maybe a little if possible) with peak around 5700-6000.
Thanks
Thanks
THey had a couple different ones. Are yours 20 or 23 degree. The 20 degree wasn't that bad of a head. For a 450/450 383, they wouldn't be a terrible choice if you have them. Of course the latest AFR and other heads are certainly better. But I've seen them dyno 450/450 on a 383 with a little bowl cleanup. Some local guys here go mid 11's with them on street cars.
I think you mean Canfield..Solid LT1 wrote:If the heads have freeze plugs in the ends they should be Canton racing heads, not a bad piece they will easily make 450HP on a 383 with a little tuning up.
"Quality" is like buying oats. You can pay a fair price for it and get some good quality oats,
or you can get it a hell of a lot cheaper, when it's already been through the horse.
Nil Satis Nisi Optimum
Ed Curtis - www.FlowTechInduction.com
I have a set of 20 degree valve angle SBC Holley heads, whoever designed
the ports did a very good job, the ports are a little small for a 383, will work
just fine with porting.
They have potential for more power than what you are looking for. The
biggest problem with these heads is the valve guide boss is huge, it fills
up the small port limiting flow. Fix the problem there, work the bowl, work
the short turn and open the push rod pinch.
Can post pictures ported when I get home in a couple of weeks if your
intrested
intrested
The Holley heads both SB & BB Chevy are Brodix castings.automotive breath wrote:I have a set of 20 degree valve angle SBC Holley heads, whoever designed
intrested
Ron Miller
Are you sure? I had a set of their BBC a couple years ago and I swear they were identical to the Canfields... So confusing when bean counters run (ruin) a company...Ron Miller wrote:The Holley heads both SB & BB Chevy are Brodix castings.automotive breath wrote:I have a set of 20 degree valve angle SBC Holley heads, whoever designed
intrested
EDC wrote:Are you sure? I had a set of their BBC a couple years ago and I swear they were identical to the Canfields... So confusing when bean counters run (ruin) a company...Ron Miller wrote:automotive breath wrote:I have a set of 20 degree valve angle SBC Holley heads, whoever designed
intrested
Canfields are casted by Brodix, Holley is casted by Brodix.
Also what is meant by your quote ?? So confusing when bean counters run (ruin) a company...[/quote]
Ron Miller
When Holley was purchased by an investment firm things when to crap! (re: WR Grace and Mr. Gasket)Ron Miller wrote:EDC wrote:Are you sure? I had a set of their BBC a couple years ago and I swear they were identical to the Canfields... So confusing when bean counters run (ruin) a company...Ron Miller wrote:
I’ve wondered if the Holley 20deg SBC heads would have some potential and enough
material in them to make it worth doing a port for a 400cube deal. If they were cast by
Brodix I would think they would have plenty of meat in them to make the csa correct.
If not (anymore) does anyone know if they have enough meat to be really worked?
automotive breath if you could post some pics that would be great.
67 camaro
girly rollers on pumpgas:
62 Nova cruiser
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
62 Nova cruiser
224/224 HR cam
1.57 10.97 @ 121.2
