Is there a basic formula to figure size requirements? Any help would be appreciated. Thanks Guys
Chad
Help with sheet metal plenium size
It depends on RPM and the number of cylinders drawing from the plenum, but there's a good article in the February '06 Popular Hot Rodding on fabricated manifolds, and one of the builders they interview, John Beck www.beckmechanical.com , says it should be about the same volume as the engine; smaller improves torque, larger improves high RPM power.
David Vizard, in his How to Build Horsepower Vol 2. says the plenum doesn't really work as a Helmholtz resonator with more than 4 cylinders connected, but gives numbers for 2, 3 & 4 cylinders (e.g. 2 for a V-8 ) as around 100%, 65-80% and 50 -60% engine volume respectively.
