SchmidtMotorWorks wrote:OK, here's a challenge to any advocate of reverse engineering ports with automated reverse engineering software tools rather than parametric modeling of ports and machining them with an integrated CAM system.
We can start with a scanned STL model or I will provide a set of point data that is better than any scan you will ever accomplish on a port.
I have a couple of questions to clarify.
First you mentioned "automated RE software"
By that, are you refering to a cmm running a probing cycle to collect data, (like a downward spiral path through the port)?
After considering the pros/cons, I'm very interested in an articulate arm for data collection as opposed to a fixed cmm.
When you say "scanned STL model", what method do you advocate to collect the data? I do not know the acronym...
I've seen Stereo Lithography of a solid,
Even digital images of the actual internal port used,
Or do you just mean triangulation algorithms???
Please overlook the obvious fact that I lack background in design.
I think it is fundamental that I understand the method of scanning you are referring to so that I can grasp how you are even able to model the port.
It is starting to sound like there is less and less of a difference between your methods and what I am expecting from a solution.
The programs I am considering are parametric. The changes made are associative and there is no outside translator needed.
True, I will be waiting to see the final proof, as far as the CAM side is concerned.
Also I do intend to continue discovery to determine if Nx should be my solution.
Making the world a better place... one pair of heads at a time.
The true spirit of conversation consists in building on another man's observation, not overturning it.
Edward Bulwer-lytton
