400 sbc deck hight?
crazycuda
400 sbc deck hight?
Post by crazycuda »
Anyone know what the blueprint spec deck height for a 400 sbc is supposed to be. All I have is a measurement between 9.020-9.025 in my books.
Thanks
Sorry if I ask alot of questions, but you never stop learning if you ask questions
CNC BLOCKS
Post by CNC BLOCKS »
9.025 is blue print on a 400 block.
Website is up and running
Machine shop tour
Monthly Specials
machine shop tom
Post by machine shop tom »
Many of the blocks 400 SBCs I check before decking are at 9.033" to9.035" Makes a BIG difference to zero-deck them!
tom
Wolfplace
Post by Wolfplace »
machine shop tom wrote:Many of the blocks 400 SBCs I check before decking are at 9.033" to9.035" Makes a BIG difference to zero-deck them!
tom
Inquiring minds need to know,,, how is there a difference?
If you are decking to zero what changes :roll:
As Carl stated, the "blueprint deck" is 9.025
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
machine shop tom
tom
I am speaking of the difference between an undecked block that measures at 9.035" and then decking it to 9.00" to achieve a zero-deck height. Doing so increases compression (obviously) and promotes more efficient quench. An engine with .035"-.040" quench will run more efficiently (all else being equal) and will be less prone to detonation than one with .065" to .070" (undecked).
There are a lot of guys slapping together street (and some track) engines without decking the block. When you do an engine properly for these guys they pretty much have to wear a diaper the first time they try it out.
tom
