My new Eagle crank is cross-drilled, suggestions?
Re: My new Eagle crank is cross-drilled, suggestions?
I guess FWIW I rebuilt the engine because of a broken valve tip (bought new Victory titanium w/coating) and reused the rod bearing as they are the coated ones and were in great shape. Two of the mains had junk through them so I replaced them. The oil pump is the Melling HV not the HV and HPressure one. Oil pressure is 45/50 psi max.
Dale C.
