Ball heads with lower guide support FOUND!
Regis shop supplies is stocking ball heads with the lower guide support (T&S design). You can purchase these at any Regis distributor (although the only one I know of is Mansfield Shop Supplies).
Dennis
Dennis
Thanks Dennis ,
i'll purchase a few before or in case they decide to change design ??
the only potential problem with "lower-support" is when you need
to mill valve job for smaller diameter Exhaust/Intake Valves
then the inner portion of Profile Cutter may interfere with lower support
....on a few i've had to modify the inner side to gain enough clearance
between the lower support and the bounce spring coils.
Re: Ball heads with lower guide support FOUND!
Be VERY careful dealing with these people, ..airflowdevelop wrote:Mansfield Shop Supplies
Dennis
Curtis
Race Flow Development
Simultaneous 5-axis CNC Porting
http://www.raceflowdevelopment.com
mansfield
I made a appoitment one time to see a piece of equipment at there shop. I got there and there was no-body around.....
The guy that grinds my cranks bought what was described as a cherry grinder from them. They dropped it off and it was all rusted and missing parts. They did give him a bit of money back but nothing to speak of....
I have herd other stories but they are the only 2 i can prove....
Keith
Keith
“If I hit you with this you’re going to be numb, that’s why they call them numb-chucks “Si Robertson
It is true, be very careful dealing with them, I lost MANY THOU$SAND$ over a brand new crank grinder that was no good and sat in my shop for over a year during the legal process that ensued. This was almost 10 years ago but I don't think anything has changed! A few people in the machine sales business from down south where they are from don't have much good to say about them either.
