Question about Pistons
can anyone tell about these pistons. Are they a good piston to use in a streetstockmotor will they hold up it the heat of a dirt motor.
keith black FHR (forged head relief) forged series piston
manley performance (sportsmaster forged pistons)
RE
I was told i need to buy a set of $550 of mahle piston. that i would pull the top off KB, Probe, and manley pistons. i am just getting started and don't have alot of money to spend on just pistons. tring to find the best piston out there for $250 to $300.
thanks for all the help
- New Member
Re: RE
I have used Probe pistons for 12-15 years and never had a problem with them.DJ5 wrote:I was told i need to buy a set of $550 of mahle piston. that i would pull the top off KB, Probe, and manley pistons. i am just getting started and don't have alot of money to spend on just pistons. tring to find the best piston out there for $250 to $300.
AFAIK they don't make hyper-u-crap-tic pistons. Don't really know that,as I don't use them, and haven't asked them about any.
LR
Re: RE
It sounds as if the person who told you this makes more money selling the Mahle piston than the others. Or maybe he doesn't sell anything but Mahle.DJ5 wrote:I was told i need to buy a set of $550 of mahle piston. that i would pull the top off KB, Probe, and manley pistons.......
In the application you describe above, what would cause you to "pull the top off" a piston?
If you have a typical Street Stock/Sportsman budget, I don't think you need that hardcore of a piston, although they will work fine. I have found the hypereutectic piston will typically last 1 season(12:1, 2bbl, 6500-7000rpm). At teardown, it was usually evident the wrist pin was trying to push it's way out. If the racer passed on the freshen-up, and tried to get a second season from the pistons, they were on the WillPop plan. A forged piston will last 2 seasons or more, if treated right.
So the forged are more expensive up front, but as cheap or cheaper in the long run. With the added benefits a forging brings to the table, it's a no-brainer if you can possibly afford it. If you can't, run 'em, throw 'em away...every year.
There are cheaper alternatives in a forged piston. Probe, JE, Wiseco, etc...they all make a good budget forging. I've had availability issues with Speed-Pro and Manley in the recent past, but I am a very small potato in the eyes of a distibutor.
For the $$$ i do like what KB offers. as stated a few posts back, be very carefull of your top ring gap. for a typical 4.030" bore, you'll find in need around .026"-.028" gap. a tight gap could blow the tops off, and that is probably what happend to your source of that info!
The problem i have with any Speed pro piston is they have very poor pin oiling. KB has forced pin oiling which goes along way.
Good luck with your decision.
Mike Theroux
www.mikesportingservice.com
Mike Theroux
Mike Theroux
www.mikesportingservice.net
There is never enough time!!
