At what point are roller cam bearings an advantage? Is it a function of spring pressure?
Don, I listened to "33 Steps" today (about five times). I liked the part about thinking like a genius.
Thanks!
ROLLER CAM BEARINGS
- New Member
ROLLER CAM BEARINGS
If you always do what you have always done,you will always get what you always got.
Re: ROLLER CAM BEARINGS
Thanks for the nice comment. Do you race Stock Eliminator?
When you can afford them. No really, I think every engine would be better off - no destroyed blocks from spun cam bearings, less oil consumption (which allows you to free up some HP in the oil pump)...STOCK 1090 wrote:At what point are roller cam bearings an advantage?
In Memory of Don Terrill
SpeedTalk Owner/Admin
- New Member
Don,
Yes I am a Stock / Superstock guy. We enjoy going for the records.
I have not had issues with cam bearings spinning. I was just wondering if there are advantages to lower HP applications. How much oil do the roller bearings require? With a stock wet sump set up we fiddle with the pressure but are there ways of controling the gpm? Has anyone found any gains here.
Thanks
Richard Scaricamazza
Thanks
When you're on the dyno with a dry sump engine it's easy to test what oil pressure does - lower psi always equals more HP. It's at least 1hp per 10psi.
Roller cam bearings need no direct oiling. They lower engine oil consumption by ~30% so you can also use smaller pump gears.
