Bearing nomenclature
BrazilianZ28Camaro
Post by BrazilianZ28Camaro » Tue Apr 09, 2013 2:55 pm
I'm just curious, why .001" bearings are called "undersize"?
I understand they increase the running clearance by .001 having the I.D bigger in relation to a STD bearing, so, shouldn't they be called oversized?
'71 Z28
Pump gas N/A SBC 427
3308 lbs-29x10.5 Hoosiers
robert1
Re: Bearing nomenclature
Post by robert1 » Tue Apr 09, 2013 2:59 pm
CB663H1 is an undersize bearing. It doesn't add .001" it takes away .001". CB663HX adds clearance.
lorax
Post by lorax » Tue Apr 09, 2013 3:02 pm
BrazilianZ28Camaro wrote:I'm just curious, why .001" bearings are called "undersize"?
LIke robert1 posted, 1 bearings tighten the clearance .001
X bearings add .001
BrazilianZ28Camaro
Post by BrazilianZ28Camaro » Tue Apr 09, 2013 3:08 pm
Ok, thanks but lets say If you have a set of .020" rod bearings and need .001" more clearance you should get .021" rod bearings called undersize?
'71 Z28
BrazilianZ28Camaro
Post by BrazilianZ28Camaro » Tue Apr 09, 2013 3:17 pm
X bearings add .001
I do believe these are from Clevite PNs?
Do you know how King bearings define their PN code in relation to size?
Say you have the #CR 807SI 020 and need .001 more clearance, do you get the CR 807HPN 021 or ??
I looked at the King web site but it was no help.
Thanks
'71 Z28
lorax
Post by lorax » Tue Apr 09, 2013 3:20 pm
BrazilianZ28Camaro wrote:Ok, thanks but lets say If you have a set of .020" rod bearings and need .001" more clearance you should get .021" rod bearings called undersize?
No, you would get .019 if you use a Clevite. If you use a King, then you get 20X
BrazilianZ28Camaro
Post by BrazilianZ28Camaro » Tue Apr 09, 2013 3:26 pm
thanks Lorax
That's what I thought=.019" undersized in relation to a STD bearing.
'71 Z28
BrazilianZ28Camaro
Post by BrazilianZ28Camaro » Tue Apr 09, 2013 3:31 pm
Got it...
and the Sealed power PN for that size is the Z87100CH19...
'71 Z28
ProPower engines
Post by ProPower engines » Wed Apr 10, 2013 3:15 am
You are more likely to find the +/- .001 bearings in Clevite or ACL. FM seems to be hard to get these days and always seem to be back ordered.
The others seem to have good stock when needed.
You can get a 009 .010 .011-.019 .020 .021 for under sized journals and a 1X for less clearance and a -.001 .002 in the HP series of bearings.
user-z68766209
Post by user-z68766209 » Wed Apr 10, 2013 1:20 pm
One thing to note...first I know your overseas so it it tough anyway.
Bearing QC is not very good and you can end up with a set of std and a set of .001
that only change the clearance from .0003 to .0012
so if you can check the clearance with what you have ..ball mic the bearing and
then who ever you order your bearing from see if they can ball mic the thickness
and do the math to make sure you get what you need.
BrazilianZ28Camaro
Post by BrazilianZ28Camaro » Wed Apr 10, 2013 6:14 pm
OK
Thanks for the tips fellas.
'71 Z28
engineguyBill
Post by engineguyBill » Wed Apr 10, 2013 10:17 pm
Brian B wrote:One thing to note...first I know your overseas so it it tough anyway.
The problem with checking the bearing shell thickness is that this will not necessarily tell you what the verticle oil clearance will be when the bearing is installed. There may be variations in housing bore diameters and the various bearing manufacturers do have differing spec's for bearing crush. The only way to verify verticle oil clearance is to torque the bearings in place and measure with a good quality dial bore gauge.
Bill
SAE Member (25+ years)
ASE Master Certified Engine Machinist
- Theodore Roosevelt
