700hp pump gas bbc 496
Re: 700hp pump gas bbc 496
A beast indeed I just finished install going to get fuel and steamed distilled water ready to fire up...
Nice work! Grab some steam-distilled spirits while you're out
Shawn
Shawn
Live in such a way that those who know you but don't know God will come to know God because they know you.
No mate ! you've got the wrong end of the stick ! efficiency comes in many forms, lets look at gas flow for example, or RPM 's it's a lot easier for me to get more hp / cu " out of a 100 " eng than your 500 " .... I'm not saying it can't be donejustahoby wrote:900cc geo metro 56mpg 1700lb car(55hp)? 454 t56 4000 lb lowered truck 18-20mpg only because I drive chill 70mph at 1700 rpm(480 hp, 530 tourque)?.Or a 305 in a Buick Roadmaster station wagon getting just shy of 30mpg(200hp maybe on a cool night)? YOu tell me whats more efficient? The amount of fuel I use or how much of that fuel is being transfered to either HP or working torque?. Those kinds of displacement should be getting 90mpg if they are so efficient. Efficiency can be viewed by intended purpose too... is 500cu in (8,226 cc) less efficient for pulling a skid with a truck or a 1.2l at 6200 rpm?lada ok wrote: but you have to realize that these small eng are way more efficient than a 500 " v8 do able but not with out a good wallet
And cost? I Am doing a 496 with a used crank, new rods and ported 781s for around 2300 bucks... down the road if I wanted to throw heads on my own time 700hp is possible if I desired. HOw do you think Vortecpro builds his engines cost effectively to make a profit? Magic?
Nice results! What heads/ intake and carb did you use?David W wrote:The cam specs are
261./265. @.050 108 lobe seperation
gross valve lift IN .663 EX .629
1.8 roller rockers with a single plane intake
706hp@6300rpm&654ftlb@4900rpm
10:2.1 compression
Build it Once Build it Right!
Dart pro 1's 275 oval port worked over alittle the exhaust is almost flawless out of the box.I have been driving the car around and one thing I noticed is that it didn't clean up off the cam until 2800'ish with 3:73's.I can see putting in 4:11 gears in pretty quick. On the freeway its great on the side streets not so great banging and popping.i guess drive around in secong on side streets
From page 1David W wrote:The cam specs are
and you'll need a cam around 260@.050" on the intake.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Right on the money as usual Mike.
I threw together some parts left around just to dyno and here were the results.
8.2:1 489 cubic inches
270/280@.050 .700/.700 108
merlin 320 ported 2.25/1.88
ported victor 1250 dominator
631 tq 671hp
non corrected was 590 hp lol
631 tq 671hp
yeah Mike Jones you nailed it on the cam specs I know some builders could do it with less but for the average Joe this combo works well
I had Mike grind a flat tappet cam for a 380 2bbl dirt track motor. He said it should make 450 hp. On the second pull it made 448. I don't know how he was so far off. Oh well, nobody's perfect.David W wrote:yeah Mike Jones you nailed it on the cam specs I know some builders could do it with less but for the average Joe this combo works well
That's a lot of cam for that compression! did it pull those numbers on 87 octane?MTENGINES wrote:I threw together some parts left around just to dyno and here were the results.
631 tq 671hp
Pro question poster.
non oxy 92 and 38 degrees timing. didnt try 87 since i already had 92. i would like to have seen what it would have done with a tuned carb, as i didnt want to dick with the 1250. was reeeeaal fat from 4500-5500 then perfect from 5500 to 6300. then fat fat fatty after. just wanted to prove to a few friends that you can poop 600hp with the wrong parts and under 500 inches.Bob Hollinshead wrote:That's a lot of cam for that compression! did it pull those numbers on 87 octane?MTENGINES wrote:I threw together some parts left around just to dyno and here were the results.
631 tq 671hp
Bob, keep in mind a Super Stock peanut port 470, flattop piston, 236 peanut port heads, solid roller, Q-jet, 720 HP, under 9.1 compression.Bob Hollinshead wrote:That's a lot of cam for that compression! did it pull those numbers on 87 octane?MTENGINES wrote:I threw together some parts left around just to dyno and here were the results.
631 tq 671hp
720 with peanut port heads, I would have never have thought that was even close to possible
Imho its all in the details, if you have the correct combination of parts and use your head get good machine work and get all the clearances right I feel the number your after will be there
Too many magazine articles make it seam like you just bolt together parts and wala your a hero but it doesn't work like that
too many people are after numbers including my self when we should take a step back and think about what the engines going to be used for and how much maintenance the customer is willing to deal with.jmho
