You can get oil thrown into the head by the crankshaft? Or you ASSUMING he has drain lines from the valve covers to the pan?Kevin Johnson wrote:That is probably simply a result of the sump and draining oil rushing forward in the pan because of the reversed Gs in braking -- I am guessing your pan is shallower at the front? If your drain tubes/passages from the head are not shielded there is a good chance oil will be forced up them by the rotating assembly particularly on the upstroke side or USA passenger side head.
Too much oil!
Re: Too much oil!
Re: Too much oil!
check your private message.
strangemagicperformance.com
Re: Too much oil!
Some engines do get massive amounts of oil thrown into the heads by the crank but you're right, I should not generalize. If the pan is shallow at the front the air churned into the oil by the crank will drastically lower the oil pressure. Check the design of the pan.lorax wrote:You can get oil thrown into the head by the crankshaft? Or you ASSUMING he has drain lines from the valve covers to the pan?Kevin Johnson wrote:That is probably simply a result of the sump and draining oil rushing forward in the pan because of the reversed Gs in braking -- I am guessing your pan is shallower at the front? If your drain tubes/passages from the head are not shielded there is a good chance oil will be forced up them by the rotating assembly particularly on the upstroke side or USA passenger side head.
The key information was that the oil pressure did not drop until heavy braking began. That is different from "when I go through the finish line." After I go through the finish line.
- New Member
Re: Too much oil!
I think I have the solution now. Well, that loss of oil problem cost me a spun rod bearing. I got rid of my old pan and got an 8 qt flat bottom pan with windage tray and baffles, a standard melling race oil pump. I had the engine on a dyno last week and it did some good numbers......now it's time for the real deal.....Famoso Raceway in Bakersfield CA. It's is too hot walk up here but as soon as we have some air I will be out there beating the hell out of it. I want low 8's and no oil on the track!
Re: Too much oil!
From the symptoms you describe, it sounds like you have too much air in your oil. Aerated oil does not drain, pump, or lubricate well. You need GOOD oil control in the pan to keep air out of the oil. Typically that means a deep pan and scrapers. Since you have spun a bearing, I think you should try a WELL DESIGNED dry sump system. The main purpose of a dry sump system is to eliminate air in the oil, since oil is sucked from the bottom of a deep tank, deeper than you can fit under the engine. Also, the thicker the oil you run, the longer it takes for the air to come out of the oil. What weight oil do you run?
Kirkwoodken
Kirkwoodken
- Dave Koehler
Re: Too much oil!
If it has 15 lbs after lifting it sounds golden to me. That's a long way from zero.
What was the problem again?
