Block cleaning
Re: Block cleaning
The oil galleys have not been a problem. It can be hard to rinse out the bolt holes. I find it best LEAN the block 35- 45 degrees toward you the side you are rinsing, so the water drains right back out of the holes by gravity.
Re: Block cleaning
Yes sure, no problems with bores and bolt holes. I'm mainly worried about very small particles in the cleaner media in the oil galleries that will damage the bearings.
Is ATF and nylon brushes going to remove all of them from there?
Re: Block cleaning
no, but that would be good thing to try if the caustuic soda was not able to desegregate it, which can happen in rare cases.
Re: Block cleaning
I use very hot water, Dawn, and engine brushes.
I like to cut off the engine brushes loop on the handle and chuck them up in a cordless drill for easier use.
Rinse with very hot water using the brushes again.
Blow it off with a 2 cycle leaf blower because the hot exhaust has a lot of oil in it.
When dry I'll wipe it down with a rag and engine oil.
In the winter I'll let set the block on top of the wood stove so the heat drys it faster.
It's kinda shade tree but I've never had a problem relating to cleanliness using this method.
Re: Block cleaning
Lizardracing wrote: ↑Sat Dec 23, 2017 4:09 pm I use very hot water, Dawn, and engine brushes.
Thanks.
What about silicon spray as anti-rust? As WD-40 doesn't work and makes blocks to rust
Re: Block cleaning
a 2 gallon pump sprayer mixed with red max degreaser, laundry soap, and hot water works good for me. Mixed with cleaning brushes and a pressure wash when done. Followed with a spray down of wd40 before blowing, then a coat of cheapo dextron after blowing off. seems to always work good and pass the white towel for me.
Sorry if I ask alot of questions, but you never stop learning if you ask questions
Re: Block cleaning
I'm a Tide guy myself... but only for the engine rebuilds. Cannot afford it for the laundry...
Re: Block cleaning
Read the MSDS
If it's not working ont he zep site
Just google "ZEP -part number- msds"
Re: Block cleaning
Ah yes, but what's the exact name of the ZEP product you use? There are a lot in their catalogue, thanks
Re: Block cleaning
#11263
I don't know if it's really a good deal, or better or worse than anything else, but they have a sales guy that comes around, IN PERSON a few times a year and that's rather nice tradition to maintain.
It used to be that way with many suppliers, but less-so every year.
These days, can't get anybody on the phone that knows squat , no instructions, ect.
IMO in this case, it would be worth calling, and asking what product they would recommend, probably.
Re: Block cleaning
He is right you know.. otherwise flushable set wipes work and are environmentally sound.rfoll wrote: ↑Fri Apr 18, 2014 10:16 am 40 years ago they told us in my environmental technology class that the government made them take the phosphates out of the laundry soap. It doesn't come out in standard waste water treatment, and produces algae blooms in the receiving stream. The result was clean water and dirty clothes. That being said, if you can find real TSP, (tri-sodium phosphate), it would be the ideal for cleaning.
Re: Block cleaning
modok wrote: ↑Fri Jan 05, 2018 9:28 pm #11263
Thanks!
