stack filtration
stack filtration
Would the below type of sockfilter cause too much restriction? To not is the sock has a spring inside to keep it from collapsing and is sprayed with oil.
Re: stack filtration
Just get rid of them;no place in any engine..
http://www.pistonheads.com/gassing/topi ... 6&d=0&nmt=
They are near useless for anything other than a pre filter. Aside from the fact they don't really filter all that well, they flow like crap which creates pulsations induced into the filter that actually help move crude thru them.
Get some K&Ns.
Get some K&Ns.
The stack bellmouths are very close together so a K&N stack filter would not work on this I guess.
Any other options ?
Any other options ?
An airbox around all the stacks on each side, and a large pleated paper filter, fed from a cool air source. As large as possible. The bigger, the better.
Before deciding that "there's no room for that", think about the loss of probably 100 hp or more that you spent time and money to gain, and then are looking at pissing it away with a crappy restrictive air supply package.
Make room for it. It is necessary.
Big plenums, big filter surface area, cool air source.
Never use hot air from under the hood for the intake if there is any way to avoid it.
My 2 cents.
My 2 cents.
This. Air box and remote filters is the way to go. How much clearance have you got from trumpet to hood?twl wrote:An airbox around all the stacks on each side, and a large pleated paper filter, fed from a cool air source. As large as possible. The bigger, the better.
My 2 cents.
that was my test. socks are at best a temporary thing to sort something that works properlyMorgo wrote:Just get rid of them;no place in any engine..
when 100% dry the run would fall half way in between the two shown
Is there room for something like this on each bank?
There are other filters (midget) on this website. You might have to make the base similar to this one.
http://www.speedwaymotors.com/Micro-Min ... 47869.html
- New Member
O.K., I'm a nobody here. A do-it-all-at-home street rat, and when I saw that filter the first thing I thought was "that would make a nice valve cover breather".Way inadequate for anything above stock Briggs & Stratton.
Something like this with half sausage style filter might work:
https://www.merlinmotorsport.co.uk/p/it ... tg-jc50ctt
However that's foam construction as well...
Wow. I've long thought that the little individual filters were restrictive, but that is simply staggering.
Make a box that all of the runners (one bank or both) can draw from, then filter the air going into that.
I've killed enough engines from poorly filtered air to ever want to think about running without an air filter under ANY conditions. I'm not rich enough or have enough free time that I can throw engines away that easily.
edit: Thanks for the link. I see that David Baker is still kicking and putting good info online.
The big issue with individual filters is that even with a long duration cam they are flowing less than 40% of the time, and so have to be really big to prevent significant air restriction during the 'gulp'. By using a plenum feeding half or all of of the engine, each cylinder effectively has the whole filter pretty much to itself.
About 3.5" right above the stacks, less above the valve covers.Cubic_Cleveland wrote:This. Air box and remote filters is the way to go. How much clearance have you got from trumpet to hood?twl wrote:An airbox around all the stacks on each side, and a large pleated paper filter, fed from a cool air source. As large as possible. The bigger, the better.
My 2 cents.
I'm not sure about that one. Not enough details to make sure. I cannot bolt the filter base plate to the throttle bodies as mosts of these type filter do, since the fuel rail and manifold is in the way. I would need to be able to mount the baseplate directly under the bend end of the bellmouths and then I would need to fab some sort of support for it (that also is a problem on this one).mystic1582 wrote:Is there room for something like this on each bank?
+ if you look closely you can see that the baseplate bolts to the throttle bodies. I've been looking at the Piper setup as well.Calypso wrote:Something like this with half sausage style filter might work:
