Try the cotton wick to introduce moisture to the center of the curing mass.Belgian1979 wrote:Hm, the PTFE didn't help. The thinner/vaseline solution seemed to work, but the center of it was still not cured. Might indeed need a lot more time to cure fully.
Going to try a vaseline/white spirit solution next, since it will disolve better.
Another separating medium that you might consider is high viscosity silicone fluid. This is marketed as nozzle gel for mig welders with a colorant added as a disguise. Dielectric grease is generally a lower viscosity version. A point of caution! Many paint shops will not allow any sort of silicone product in the door because it will negatively affect subsequent painting. Keep this in mind if you plan on painting the surface.
Did you try the bar of soap?
If you are looking for animal fat products, pure lanolin would probably work. Neatsfoot oil is another possibility. All products that I used to sell.
