602 crate cranking pressure?
Buddy has a 602 Gm crate for circle track.
Its about 10 years old, We are wondering if its getting seasoned.
Put the Gauge in 3 different cylinders, They range from 45-55psi??? LOW?
So we bring the same gauge to a friends shop who has a new 602 crate with only 1 season on it, Same thing. 55psi??
Is this SNAP-on gauge really messed up? orr... ? do they just make nothing for cylinder pressure?
Re: 602 crate cranking pressure?
Our MAC compression tester was showing some funky readings until we replaced the valve stem check valve in it. If you really want a check, pop a sparkplug on your truck and see.
GPM Race Engines
Custom Machining, Dyno Service, Automotive & Marine
http://www.gpmraceengines.com
Facebook: https://www.facebook.com/pages/GPM-Race ... 8632920064
Twitter: @ GPMracengines
we did replace the valve for fun. Read the same??
I would imagine those engines would have been 150psi or so?
If its running halfway decent its going to have more than 50 PSI cranking pressure. I'd try another tester, the parts store has a free tool rental program you can use.
GPM Race Engines
Try it a WOT.
Website is up and running
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
That's what I was thinking. I've seen many times a compression test done at idle and the results come out half or much less than a proper test.CNC BLOCKS wrote:Try it a WOT.
Put a little oil in the cylinder and see if it comes up. Cranking speed ok?
ya cranking speed is normal, ( healthy battery in both cars)
Ill try another tester, and at WOT.
both engines run good. Lots of oil pressure
At operating temp, too, if you're able to do so.
Shawn
Shawn
Live in such a way that those who know you but don't know God will come to know God because they know you.
Tire Schrader valves have way too stiff a spring to give accurate compression tester readings...evilbanshee wrote:we did replace the valve for fun. Read the same??
the gauge turned out to be junk.
havent tried a different gauge yet.
You likely don't need a new gauge, just install the correct Schrader valve for under a dollar. Compression tester check valves are pretty well all interchangeable; the Snap On p.n. is MT24DA1.
