SHOWCASE YOUR RIDES OR...........
shop, or whatever your hobby or interests are. If you have a road race car, show it. If you have a street rod, show it. If you have a drag car show it. If you have a motorcycle show it. If you just have a computer, and nothing else, than show that.
strangemagicperformance.com
Re: SHOWCASE YOUR RIDES OR...........
- af2
GURU is only a name.
An old ride,new ride in the works.
Nhra E/SA 1972 mustang coupe best et so far 10.73 -123.21 351 HO .
This is a streetcar no times yet. mild 408 Cleveland, wide ratio c-6, 3.50 trac loc.
Picked this one up a few months ago. Need to find someone to build me a 347 or 363 or something, though. The 289 doesn't push it very quickly with a C6 and 4+ geared 9" on ladder bars.
Supercharged 383, solid roller, Dart heads of unknown flow but uses a 1207 gasket, 12 bolt rear, running on our new FiTech EFI system.
383 from Blueprint, with a sh*t carb. Going to switch it to our new FiTech system soon.
Putting a 1954 Dodge truck body onto a SRT10 chassis...
Just a simpleton average garage goofball hack built pump gas all motor 289 Ford.
https://www.youtube.com/watch?v=ht10NXmZcvw
This just went bye-bye last month…
My prototype Prius beater…
This is for sale…
Somebody buy this so I can have my lift back…
This is for sale…
Some very nicely done stuff here. I'm afraid my junk pile isn't anywhere near as nice. 605 pumpgas Street Hemi 853hp&818ftlbs. Can't give you any good 1/4 times as it's been bending and breaking the chassis every time it's been on the track. Last attempt bent the chassis at the hit and went into severe chassis shake, hung with it to about the 1/8 and started loosing my vision, dropped the throttle and coasted through at 10.74@108.
http://smg.photobucket.com/user/quickd1 ... 1.jpg.html
[img]http://img.photobucket.com/albums/v514/quickd100/9ff3c690.jpg[/img]
- GuysMonteSS
Heres my '86 Monte SS,I've had it for 14 years now,street only;
Got a .060 over Mark IV,started life as a LS-6 crate motor.Its been balanced and has Brodix heads,a UDHarold solid roller cam,Manton pushrods,Jesel shaft rockers,Weiand Stealth with a BG Mighty Demon 800,and lots of other goodies.
The suspension has been worked over with adjustable upper control arms,extra tall upper & tall lower ball joints from Howe,double adjustable shocks from Viking,a Lee 670 steering box,UMI rear control arms and old school Rancho sway bars.Handles and rides pretty good,and gets driven lots in the summer.
Guy
Guy
'86 Monte SS,513 BBC,AFR heads,Bullet solid roller cam,Doug Nash 4+1 5 speed,Hurst Inline Shifter,Ford 9 inch Rearend.
