4banger wrote:I have ran into a problem that might be perfect for this thread. According to an online calculator, my header primary is too big. Can I put a header reducer in the collector and use it as a kind of merge? I am thinking of cutting collector off and inserting the reducer and welding it back up. will this work? Found a smaller header but don't have it yet. tell me what you think.....
ford 2300 pinto engine, 3.780 bore 3.126 stroke stock size valves(rules) 1.74/1.50...... 350 or 500 holley carb I think the
calculator called for primary of 1.33 the header I have now is a 4-1 with 1 5/8 to 1 3/4 primaries to 3" collector... will putting in reducer help me? gonna use the 350 carb but has the 500 on it now. Thanks for your thoughts
It is important to point out here a couple of things.
The things I am speaking about here are not the whole sum of what is involved in "making" a more powerful header.
Example:
the interface between the exhaust port and the header tubes is very important to what kind of results you will get with any other modifications further down the system.
Headers in a box, (mass manufacturing) and to a large extent even custom built headers, do not grasp nor can they afford the time it takes to make this area as good as possible. Loosing velocity and flow here is not recoverable. Hurt flow at the head and there is a direct measurable loss of maximum power. This is the case from your grocery getter car to the most powerful motors. You can not just put a smaller diameter tube header and expect it to run better. It is possible if done correctly but store bought pieces usually need to be larger as the larger tubing is the way to overcome flow losses (power) at the flange, not to mention tight radius bends. Bolting the larger header can show more power upstairs but what you give up in overall power is overlooked or ignored. This is why you see 1.75 or even 188 tubes on SB chevies that only make 450hp.
So when I point out that most headers are too big, I am talking objectively and the other part of the story is that it is not simple or cheap to get a correctly sized system that really changes things.
Glad people pick up that the collector sizing is a good way to reduce reversion and get a larger power band. Reducing tube size at the end of primaries or modifying an existing swedged collector can effect the amount of reversion but if you reduce flow potential you probably wont be happy.
