Lead balls I'm sure is the best option.... may have some lying around. Nuts and bolts, however- might be the only option.KCW wrote:50 cal. lead balls (black powder), or brass nuts and bolts to agitate inside tank. Remove any float mechanism first!
Is petcock leaking by, or externally ? Manual or automatic petcock ?
Leaking by, into the fuel line & through carbs. It's Automatic in "on"- mode by the vacum/ non vacum open/ closed. Manual shift to "pri" and "reserve"(?).
BTW: I was thinking: Isn't it supposed to be some kind of filter in the tank, on the inlet for the petcock?
(Don't have the split drawings in front of me, so.... OK will look up gogggle)
Edit: Here it is http://www.cmsnl.com/kawasaki-1986-zx60 ... 22627.html Cannot see a filter. However, My petcock does not have a high "Tower" that goes into the tank as on the drawing. Maybe the drawing is lying, or maybe there's a part missing?
Thanks
