I have a vintage low revving carbureted 500cc application with sidedraft carb pushrod single cylinder hemi. Some street bikes and some road racers are my customers.mk e wrote:Here's something interesting, at least me. I tend to concern myself more with velocity at the seat and then taper the port from the set out so the port just is what it is. When I go back an look at my stuff while the peak in the port is .95 mach, the seat is almost exactly .6 mach at the hp peak.twl wrote:I purposely set my CSA to be give .6 mach where I want the hp to peak.
I set the CSA at the carb venturi for max atomization over the jet, and then widen the port at the bowl to the large valve(valve larger than the carb).
I always used to think that this was a "backwards" port design, but it actually makes perfect sense for this kind of application, and it delivers very good flow and power like that. The carb size sets the choke point rpm for max hp, and the port is made to flow the necessary cfm to feed the demand at that rpm. This yields good power at the top, and retains excellent lower rpm and midrange rpm torque because nothing is oversized beyond the intended limits which are either mechanical limitations or desire for low rpm tractability on the street.
