Starting on a SB2.2 engine build
wyrmrider
Re: Starting on a SB2.2 engine build
Post by wyrmrider »
ask Jones
you can get a bigger wheel with the .937 but mike can tell you if it's worth it
69434
Post by 69434 »
wyrmrider wrote:ask Jones
Yes he was the one that recommended either a .904 bushing that he sells or a Jesel .937 keyway (expensive) & a 50mm or 55mm cam journal.
decisions, decisions... #-o
'69 Camaro-N/A-23°-SBC-2988#
Best 1/8 mile pass 5.753 @ 119.92
http://www.dragzine.com/news/homebuilt- ... -1969-z28/
millionville
Post by millionville »
What size is you main journals? I'm currently building an sb2.2 myself and am looking for part numbers on specific bearings. anyone care to help a feller out pm me or something. I'm using 2.300 main and 1.850 rod journals both .010 under
69434
Post by 69434 »
millionville wrote:What size is you main journals? I'm currently building an sb2.2 myself and am looking for part numbers on specific bearings. anyone care to help a feller out pm me or something. I'm using 2.300 main and 1.850 rod journals both .010 under
2.648 mains, with a 2.10 rod journal, this is going to be a 9.325 deck 454ci.
http://www.summitracing.com/ for parts
69434
Post by 69434 »
Is it best to go with the longest rod possible?
I was thinking 4.185 bore, 4.125 stroke, 6.25 rod, 1.0 CH piston.
69434
Post by 69434 »
Going with a Jesel .905 dog bone lifter with a .820 wheel set-up & a 50mm roller bearing cam journal.
wyrmrider
Post by wyrmrider »
why the small wheel?
is that as big as you can go with 50mm
ASK YOUR CAMGRINDER
#2 longer is better- looks good
longer rod changes cam
ASK YOUR CAMGRINDER
69434
Post by 69434 »
wyrmrider wrote:why the small wheel?
ASK YOUR CAMGRINDER
ASK YOUR CAMGRINDER
Jesel dog bone lifters with a .905 offer only 2 wheel diameters .820 & .785
& a 50mm will keep more oil away from the cam than 60mm Babbitt bearings.
2 engine builders & 1 cam grinder said that will work & be plenty big for what I am doing.
jacksoni
Post by jacksoni »
The 1.850 rod journal is a Nascar or IRL diameter. They are not available, at least from Clevite- you need to check other sources- in a .010 undersize bearing. They require either a 2.008 or 1.976 rod big end bore. The rods you were looking at designed for a 2.1 rod journal will not work. There is a Nascar rod journal in the 1.77 range (don't remember exact dimension) for which bearing are available. You will need rods that have the proper bore for the bearing/journal. they may be available as Nascar take outs but the ones for 2.1 journal aren't it.
I have used LSM rollers in a .937 diameter with .850 roller. Dimensionally the same as the Jesels. I did not find they lasted as well roller failures and bearing wear. The Jesels are more expensive but can be rebuilt. I used a 55mm cam core which was OK The Valve train was all Jesel with titanium valves. Springs PAX 1329 and 1326 (400 seat, 1000open approx.) 9500-9800 in a LSR car. Rpm needed to make the power I wanted. Nothing lasted quite as long as I thought it should so I was behind the replace the parts curve. Your 1000 mile replace the valve train with mostly easy street miles might do it.
69434
Post by 69434 »
Ran all the numbers through my PipeMax software & came up with 1113h.p.
If everything is perfect on the build & dyno I think it should be close to this.
69434
Post by 69434 »
Opps fat fingered the h.p. number on my PipeMax software
It should be more like 1013h.p. if the VE is 110%
69434
Post by 69434 »
Does the SB2.2 head have the same firing order as a LS head?
68rs406
Post by 68rs406 »
69434 wrote:Does the SB2.2 head have the same firing order as a LS head?
It's whatever the cam is designed for, mine is 18436572 like a standard SBC.
Sean
69434
Post by 69434 »
Comp Cams said if they did my cam it would be an LS firing order.
I guess the firing order can be what ever you want it to be?
wyrmrider
Post by wyrmrider »
UH NO
you are limited to crank layout and two crank revs per spark
