wyrmrider wrote:
FIRST CLASS- you have to make a head change
IDK if 72 heads have hardened ex valve seats I'don't think so- which heads do you have
I forget the casting number, but they are the fist series of open chamber heads w/o hardened seats.
In order to make a BBM work you need quench
The combustion chamber stock is the worst- low spark plug on one side giving a pancake shaped chamber and trying to ignite it from the side
Cast Iron Heads for stock look
67 heads from any 67- 915-- put in hard seats (durabond) and 1.81 ex and 2.14 intakes
with .500 lift cams I'd go 30 degree seats on the intakes
http://www.victorylibrary.com/graphics/poly/vizard3.jpg
new bronze guide inserts and a nice valve job with a bowl clean up or a pocket port DIY is OK
OR
you can weld up the chambers in your heads if this is a matching number requirement
Speed-O Motive did this
Should I just skip all that and buy 440 Source Stealth aluminum heads? They already have the closed chamber design, larger valves and hardened seats. They look close enough to stock on the outside for my purposes. I'm not worried about having the correct casting numbers on various parts. I just don't want to lose the original serial number stamping on the pad of my block.
you need D-dish 0.0 deck pistons
The problem with zero decking is that will obliterate the original serial# that Jensen stamped on the pad of the block.
I hear you about quench. It's probably going to be my biggest problem. I'm going to have to do a full rebuild w/ bored cylinders* and no decking and hope that the flat top pistons are close enough to the deck to get some quench with a shim head gasket.
*I'm assuming that even if I pull the heads off and find NO bore ridge, that I still should NOT put pistons in with a taller compression height without boring first? Would that be asking for trouble (to put in standard sized pistons with different compression height, even if I can't detect a bore ridge)?
OR
I will have to live with about 8.5:1 CR that I will get with the stock pistons and a closed chambered head...and no quench.
use this Mike Jones cam- there is nothing else even close- except Mikes inverse radius Hyd roller
H440D64307 256° @.006 202°@.050 .307″ cam lift .461″ valve lift with 1.5 rockers or.491″ with 1.6 rockers- which I recommend on the intakes only but ask Mike.
Let Mike pick the exhaust based on your exhaust- let mike pick the compression depending on which combination you use.
gather this information
http://jonescams.com/street-performance/
also in your RPM range get your carb dialed in and ask Mike how much carb you need for your gearing and converter
Yeah, I definitely want to invest in the best cam I can get. I suppose I need to get all the other details worked out in order to give him the info he needs to spec the right cam.
BBM do not like a lot of overlap
Good to know.
The Magnum/HP cam that is in there now is supposed to have 46 degrees of overlap. To me, it 'sounds' just right, and I want it to sound close to stock anyway. Does 46d of overlap on a street 440 sound reasonable to you based on your experience?
post results of compression test and let's see what the basic condition is
Will do.
