CMD good stuff!
CMD good stuff!
Hey I took some advice from on here to try the CMD #3 EP lube on my rod bolts and I love how smooth the pull is with no galling on the cap. With the CMD my torque was 10 lbs less to get the same bolt stretch as before using ARP ultra. As long as you have a bolt stretch gauge I would recommend the CMD over any other fastener lube avail. The stuff is real thick so a little goes along way. 1 tube should last a guy a lifetime!
Re: CMD good stuff!
I have honestly been using CMD#3 for over 60 years. Many people use it because it works. No moly to clog oil filters. Dissolves in oil eventually. Has been used on lathe centers and deep draw dies for years. I smear it on solid lifter camshafts for break in, all torqued bolts, rocker sockets, clutch arm balls, pilot bearings, great ball bearing lube, etc. I buy mine from Scott Special Tools in St.Charles,MO. They are right up the road from Ron's Porting and Bob Stiegemeier's dyno shop is a stone's throw away. ALL are good to do business with. Bob helped me pick up 90 HP with leaning out my Rochester FI. Ron has supplied ghost porting for quite an impressive list of customers. I haven't seen him for a few years, but I imagine his CNC's are still running every day.
Kirkwoodken
Kirkwoodken
Re: CMD good stuff!
Kirkwoodken
Kirkwoodken
Re: CMD good stuff!
Looks like Dart, Manley, and Goodson sell the same stuff maybe relabeled? http://www.summitracing.com/parts/drt-lube
Pro question poster.
Re: CMD good stuff!
Yeah, tightening fasteners with well prepared mating faces and proper lube is a pretty luxurious and confidence inspiring feeling.
I always wonder how many fastener "failures" started with slip stick or otherwise jumpy tightening that happened to end up with the torque wrench needle falling on the right value, or refusing to move beyond it.
Re: CMD good stuff!
It also works great on live carbide pilots for valve seat work.
Jim McMahon
Heads1st
http://www.heads1st.com/
Heads1st
Re: CMD good stuff!
Im a little hesitant on using it on studs as you cant measure stretch like you can on a rod bolt. I did however notice 10 ft less on the torque wrench compared to ultra torque when stretching rod bolts. You can for sure feel less friction on the pull with CMD.
Re: CMD good stuff!
yup..look closely at a national event.most comp and prostockers use it exclusively on valvetrain stuff.maybe others,but that's all I follow
Re: CMD good stuff!
I've been using it for 40 years and it is THE best for fastners, flat lifter cams etc.
Re: CMD good stuff!
Are you guys using this stuff on head and main studs? How do you figure final TQ? From what I have seen with it causing less friction than ARP lube..
CMD good stuff!
For guys like me that have older cars, CMD #3 also comes in 14 ounce canisters for grease gun usage. You will love squirting this stuff in old ball joints and king pins. $101.15 for a case of ten direct from CMD. If a 4 ounce tube will last a lifetime, think how long 14 ounces will last.
Kirkwoodken
Kirkwoodken
Re: CMD good stuff!
Any special procedures when using CMD for cam break-in? Degrease the cam and apply?
Re: CMD good stuff!
Never tried it for cam break in
hope we get some answers from those with experience
First- try and dissolve in engine oil
if it will not dissolve (like whit grease ) DO NOT USE
Re: CMD good stuff!
Here is a reprint of one of my older CMD #3 posts:
I started using CMD on all new stock Chevy rockers and never had a single failure with any valve spring loads. Didn't know Mike used it, but CNC Carl has mentioned it on SpeedTalk.
I've been buying it here for 50+ years:
email: sales@scottspecialtools.com
phone: 636-939-5771 / 800-638-7277
fax: 636-939-5793 / 800-532-1755
CMD #3 is good for just about ANY extreme pressure lube need: flat lifter cam breakin, pushrod ends, around valve keepers so they are easy to remove, poly rubber lube. I put it only on lifter bottoms so it does not deter spinning.
My other favorite anti-seize lube is Kal Gard Chain Cote moly chain lube:
"CHAIN KOTE is a specially developed lubricant for heavy duty roller chain applications. Chains have a unique requirement in that the lubricant must be very thin to penetrate the critical inner roller area, but thick enough to resist being thrown off at high speeds. CHAIN KOTE is the perfect answer. It has a thin, penetrating lubricant that carries a high concentration of Moly and a high viscosity bonding agent which bonds directly to the areas of maximum load and wear. CHAIN KOTE will not be thrown off your chain at high speeds when properly applied."
Part# 00717 | 13 oz.
https://search.yahoo.com/search;_ylt=A0 ... ch&iscqry=
I've also used it very successfully as a cam breakin lubricant. It is a heavy moly lubricant with a great tenacity. It is hard to wash off with gasoline. Holds up well to oil splatter. My favorite chain lube for dirt biking; the ONLY lube I used that would still be in the master link after a day of riding through puddles. Also came in #1 in the Dirt Bike Magazine Chain Lube Shootout.
Mike's comments, as usual, touches on all the really important stuff: burnishing the threads and bolt/nut seats. That preps the bolt mating surfaces to hold torque and come apart properly, which happens at loads normal oils will not hold up to. Extreme pressure lubes are made especially for that purpose. Although the threads on the rod bolts are rolled, which leaves them with a very smooth finish, the female threads in the nuts and rods are made by cutting with taps, and have tooling ridges that need smoothing to get consistent holding power.
Kirkwoodken
Kirkwoodken
