I would expect they all do. I'm using a Freescale ignition and coil driver IC. Like what Joe 90 was pointing out with the LS ignition, there is a very small resistance in the circuit for the coil primary. This is used to monitor the current flow in the coil primary. When the primary has energy put in to it and it is then shut off, the energy is expected to do work by lighting a spark on the plug and going to ground in the engine block. If the spark does not occur ( and the coil wire isn't shorted to ground ) the current in the coil primary doesn't decay as quickly. All that energy has to go somewhere and it is being absorbed by the transistor that drives the coil.No manufacturer that I am aware of directly detects coil failure. They just whine that there is a misfire and it is up to you to figure out why.
This extra energy being absorbed by the coil driver can eventually lead to failure. Well, it will lead to failure because someone can save a few cents by using a smaller transistor here if the driver circuit is smart enough to turn it off or reduce it's power when there is trouble. So that is what you get.
