Chevy's old 30-30 cam spec's.
- Show Guest
Re: Chevy's old 30-30 cam spec's.
A popular Racer Brown cam made 70 MORE pounds of torque at 3000 RPM than that cam, and the same top end power in a 327 Chevy, back in the late 1968
JOE SHERMAN RACING
JOE SHERMAN RACING
Joe,
Please post up Racer Brown's cam spec's for the one you mentioned so I can compare it to the old 30-30.
I try to file this stuff away for historical reference is why.
Thanks.
Thanks.
Total lift was all they checked on the Lunati stocker cam. Modern stockers like I had run mid to low 10s now but you cant compare the motors or the "enhancements" today to yesterday. Totally different rules and transmissions now.
I had a guy bring me a 383 powered Chevelle one time made 0 vacuum and would not idle with less than 26* timing.
Cranking compression was 75 psi across the board.
Di some checking and the seat to seat times on the cam were outrageous! Turns out he had a 30-30 cam in there with hydraulic lifters.
He just spent 600+ dollars at another shop to buy and install one of those electric vacuum pumps on it to get the brakes to work.
He was broke so I put a TQ40 Erson in it and he was all good.
LOL. I got into a "discussion" at a car cruise with some old timer that INSISTED that it was A-OK to drop hydraulic lifters in an OEM solid lifter application if you wanted a quiet valvetrain and no lash adjustment. Said he used to do it all the time with Z/28s, L78s, etc. I tried explaining that it wouldn't work too well. I should have just let it be, but he was giving this advice to someone building an engine. After a while I just gave up arguing, as he didn't want to hear it. Hopefully the other guy didn't follow this wise advice.EthylCat wrote:I had a guy bring me a 383 powered Chevelle one time made 0 vacuum and would not idle with less than 26* timing.
"There are some people- if they don't know, you can't tell them." Yogi Berra
I knew a fellow who put roller lifters on his 30-30! I told him that wouldn't last long. It didn't last long.
Kirkwoodken
Kirkwoodken
we used to put solid lifters on hyd cams set at .003/.005 and the cars did MPH better at the stripnovadude wrote:LOL. I got into a "discussion" at a car cruise with some old timer that INSISTED that it was A-OK to drop hydraulic lifters in an OEM solid lifter application if you wanted a quiet valvetrain and no lash adjustment. Said he used to do it all the time with Z/28s, L78s, etc. I tried explaining that it wouldn't work too well. I should have just let it be, but he was giving this advice to someone building an engine. After a while I just gave up arguing, as he didn't want to hear it. Hopefully the other guy didn't follow this wise advice.EthylCat wrote:I had a guy bring me a 383 powered Chevelle one time made 0 vacuum and would not idle with less than 26* timing.
Another FWIW. I used to advance the 30-30 8 degrees and set the rockers at .035". Made a world of difference and never hurt anything that I know of. Big improvement in torque. Those were the days when I seldom checked anything with a degree wheel. I did quite a few of the early Z/28's this way, along with timing recurves. All with headers, of course. I thought they were peppy, even with 3.73 gears. The 4.88/2.2 cars would run in the mid 12's.
Kirkwoodken
Kirkwoodken
"we used to put solid lifters on hyd cams set at .003/.005 and the cars did MPH better at the strip"
Years ago, I bugged UDHarold about a small solid lifter cam for a 283 and he said to get one of his 274 hy-cams and run solids on it lashed down like this. he went on to say that the Ford small block guys did it a lot fine for circle-track use. Of course, I figure this is a while back.
You will witness the reverse being done with hydraulic lifters on tight lash solid lifter profiles at the Engine Masters Contest this year ... guaranteed.pdq67 wrote:"we used to put solid lifters on hyd cams set at .003/.005 and the cars did MPH better at the strip"
with no take up ramps you get quicker opening of the valvespdq67 wrote:"we used to put solid lifters on hyd cams set at .003/.005 and the cars did MPH better at the strip"
I did this back in 58 when the 348 came out and no solid lifter engines were available from chevypdq67 wrote:"we used to put solid lifters on hyd cams set at .003/.005 and the cars did MPH better at the strip"
Yeah, but I am talking about the other way around (hyd lifters on a factory solid cam), which would give some pretty outrageous seat-to-seat duration, as with the "no vacuum" 383 above.pamotorman wrote: we used to put solid lifters on hyd cams set at .003/.005 and the cars did MPH better at the strip
One of my friends installed a elgin 901 which is the eq of chevys mech can and he didnt know its mech. Installed hyd lifters. This was in a 307 motor. Had a very wicked idle and slow responce on lower rpm but above 2500 it screamed. Lifters didnt last long thou. He replaced it with a 6929 chevy cam from his 327. When i asked him ge said he didnt know and needed a cam so he used it.
cheers
chevyfreak.
cheers
chevyfreak.
Bowtie for life
Several yrs. back a fellow wanted me to look & a car he couldn't get to run, turned out to be hyd. lifters on a 30-30 cam. I told him to get a set of solids & set em to .030, problem solved.novadude wrote:Yeah, but I am talking about the other way around (hyd lifters on a factory solid cam), which would give some pretty outrageous seat-to-seat duration, as with the "no vacuum" 383 above.pamotorman wrote: we used to put solid lifters on hyd cams set at .003/.005 and the cars did MPH better at the strip
Jim
