Build a Lightning Bronco?
Re: Build a Lightning Bronco?
you still got lots of good parts
find a HR block
there are differences
I have an 83 302 bronco that will need a motor someday
Lighting sounds good with an
AOD instead of C6
find a HR block
AOD instead of C6
Thanks wyrmrider, I appreciate your input. Did some research on the 351w roller blocks and found out they have a problem cracking from the spider hold downs through the cam bearing oil feed hole. I may be looking for an older block!
The F4TE will live a long, happy life for what you want and will make using a HR cam much more affordable. I'd be looking for another one.
I think you are right JWebb. I found one builder who will not us the f4te block for any applications. He states that 3/10 are cracked upon disassembly and that was while making 200hp!
Gt40 upper .015" lip
Gt40 upper quickie blend.
Gt40 lower front runner with large dog leg and only 2.09 sq in area.
Gt40 large dogleg runner rough out
Gt40 lower less dogleg runner
Gt40 lower less dogleg rough out
Lower gt40 before
I did some reaserch on this manifold and TMoss porting states that the stock lightning 351w lower flows 280 cfm! I will not be able to make the heads flow that so this may be a wasted effort but a look at the manifold with such steep doglegs I find it hard to believe it flows so well. Does anyone have solid info on gt40 intake and head flow? Stock vs. Ported. Thanks. Charlie
Stock 65mm lightning throttle body with .1" flat leading edge and .035" step before the blade.
Leading edge rough out
Cardboard protected blade.
