Build a Lightning Bronco?
Carnut1
Re: Build a Lightning Bronco?
Post by Carnut1 » Mon Nov 16, 2015 6:39 pm
af2 wrote:Also Tenatious is a word seldom used until you see builds like this.. Nice!!
I will take that as a compliment. Thanks!
af2
Post by af2 » Mon Nov 16, 2015 9:16 pm
Hell yea!!!!!! =D>
GURU is only a name.
Carnut1
Post by Carnut1 » Mon Nov 16, 2015 9:19 pm
Hell yea!!!!!! =D>
Moving in a few days and I need to finish this up for Mikey. Feelin the stress and you just made my day. Thanks!
Carnut1
Post by Carnut1 » Tue Nov 17, 2015 6:43 pm
Post mortem cont. Mains toast, crank .010 wear on rods. Cam shot.
Carnut1
Post by Carnut1 » Tue Nov 17, 2015 6:44 pm
Carnut1
Post by Carnut1 » Sat Nov 21, 2015 11:32 am
I can see the vacuum part of this build being a problem!
Carnut1
Post by Carnut1 » Mon Nov 23, 2015 7:40 pm
If all goes well we will try this out tomorrow. Wish me luck I haven't broken in a flat tappet in twenty years and never a Ford flat tappet. The lifter alignment was horrible.
Carnut1
Post by Carnut1 » Wed Nov 25, 2015 5:41 pm
Lightning engine started as soon as we gave it spark! Only let it run a minute because I have no idea where the timing is set or even how to set the timing on one of these fi Fords. Rockers seem very noisy. Hoping the rockers are not past their sweep. I would think they would be fine on this mild cam but I did not check clearance. The pushrods maybe too long too after milling heads, decking block and .027" head gaskets. Ugh, the stress. Moving to Florida friday. Need to get the bugs out for Mikey.
Carnut1
Post by Carnut1 » Fri Nov 27, 2015 7:35 pm
Thanksgiving morning and my last day to work on the Bronco. Rockers were noisy when we fired it up for a minute a few days before. Decision time, time the motor and break the cam in when I am here or let the project sit, probably till spring? Mikey decided we should break in the cam knowing that if the rockers are past their max lift and bottomed out or pushrods are too long that we could burn the cam, he decides we should break it in. So the break in went well but the tap stays the same. A fast tap, definately from valvetrain. Possible the rockers are hitting the stock gt aluminum valve covers? I don't know. No time to pull the intake back off and inspect. After break in and timing set she idled with a sweet mild lope just a tick over stock. Very responsive to throttle input, enough to nearly collapse the stock lightning air intake. No leaks of water, oil, or exhaust and no blown codes. We decided to run the stock bronco computer first. Seems fine. The exhaust is mellow going through a single flowmaster for now. The exhaust was strictly hot air and water vapor. No smell at all. I am sure an efficient burn. I just wish I had a bit more time to fix the tap. Oil free of debris and golden
bobalattie
Post by bobalattie » Fri Nov 27, 2015 9:27 pm
I have run stock rockers with e303 cam and its .498 lift, so you should be good, also they did not touch the valve covers.. Did you check each one for preload as they were being torqued and use the shims as needed to get them all close to each other preload wise?
XE lobes tend to be noisy and those cast aluminum valve covers don't help much to quiet anything down...
Carnut1
Post by Carnut1 » Tue Dec 01, 2015 4:45 pm
Sorry for the long reply time. Just got to Florida, I see I screwed this build up due to lack of experience with 351w and the non adjustable valvetrain. When I bolted it together I felt the lifter plunger travel was a bit more than I liked but thought it was ok and did not bottom out the lifter. I feel the pushrods may be too long and just using old sled rockers that sweep farther than they did with a stock cam could be causing the noise. Thanks for the input.
Gillesdecourse
Post by Gillesdecourse » Tue Dec 01, 2015 9:06 pm
I feel bad for your because you put a lot of work and care into this build and you are not able to feel the reward, yet. I'm sure it'll be a real beast once all is fixed.
Carnut1
Post by Carnut1 » Wed Dec 02, 2015 7:54 am
Gillesdecourse wrote:I feel bad for your because you put a lot of work and care into this build and you are not able to feel the reward, yet. I'm sure it'll be a real beast once all is fixed.
Thanks, except for the noisy rockers the engine sounds really nice. Just the way I wanted it. Mellow torque monster to move those big tires and plenty up top. Unfortunately Mikey will need to get someone else to pop the upper plenum off and check the rockers and geometry.
Caprimaniac
Post by Caprimaniac » Thu Dec 03, 2015 11:51 am
Sorry about Your valvetrain problems there, on an otherwise coooool build.
Hope you figure out the probs this Winter and fire up Your Bronco soon....
Nice to have a build thread on here and not just Tech- questions/ .discussions. How about a engine- build/ Project section in here?
Carnut1
Post by Carnut1 » Thu Dec 03, 2015 12:49 pm
Caprimaniac wrote:Sorry about Your valvetrain problems there, on an otherwise coooool build.
I appreciate the kind words. I did this project as a favor to an old friend as I knew I was moving away and his pride and joy had been dead a while. He will need to get some help fixing the noisy rockers!
