Another "How much will it make?" Project "Special Needs"
CGT
Re: Another "How much will it make?" Project "Special Needs"
Post by CGT »
CGT
Post by CGT »
CGT
Post by CGT »
Rick360
Post by Rick360 »
You must've paid the extra for the Dozer ported intake option. :lol:
Rick
Carnut1
Post by Carnut1 »
Love it, thanks! Hey, what is with the not so hidden braided lines?
randy331
Post by randy331 »
Carnut1 wrote:Love it, thanks! Hey, what is with the not so hidden braided lines?
Braided lines plumbed water from back of intake to front.
The other intake isn't for SN, but is for a different project. I just sent a pic to Chad so he could see what I was talking about on that intake. But I sent it at the same time so he posted it too. LOL
I just need to double check everything on SN heads/intake (and get Dozer's approval ) then clean and assy the heads.
Then decide if I'm supposed to bolt the engine back together or if Chad is ? :?:
Then dyno flowZ. :D
CGT
Post by CGT »
Lift 0.100 0.160
Diameter 2.022 1.560
Seat & Valve Face Angle 52 52
Seat & Valve Face Width 0.060 0.060
Seat Top(Chamber Side) Angle 45 45
Seat Top Angle Width 0 .100 0.100
Valve Back Cut Angle 0 0
Valve Back Angle 12 12
Area of OtrSeat to Inr Face Edge 0.401445589 0.5675668342
zums
Post by zums »
Area of OtrSeat to Inr Face Edge 0.401445589 0.5675668342[/quote]
An overlap snap shot of a nano second, is that the best choice?
Tom
randy331
Post by randy331 »
zums wrote: An overlap snap shot of a nano second, is that the best choice?
Tom
Odds are any lift/window area you end up with on an optimized combo at TDC is just the result of a compromise of other parts of the lift curve.
CGT
Post by CGT »
.006 285 289
.050 236 231.5
.100 216 197
.200 161.5 151.5
.250 137.5 128
.300 108.5 103.5
.350 72 71
Exhaust Duration
.006 300 307
.050 246.5 251
.100 215 207.5
.200 161 167
.250 141 142
.300 113 114
.350 76.5 79
Along with the new heads, I will be trying another cam I specced, after dynoing with the original Bullet. Bullet Cam is 232-252 110, Comp cam is 236-247 109. Any predictions or guesse? The numbers abover are as measured by me. Hope to be dynoing in the next few weeks for anyone possibly interested. Comp in left column, Bullet in right.
Carnut1
Post by Carnut1 »
I will take the Comp for 10. I think it will have a better balance. Thanks, Charlie
CGT
Post by CGT »
Carnut1 wrote:I will take the Comp for 10. I think it will have a better balance. Thanks, Charlie
I also believe the comp will outrun the original cam, if it can be controlled. At least I hope so, at least its on a decent core, unlike the Bullet which came on a cast core for a premium price. Carnut, Balance? Like Split I guess?
Carnut1
Post by Carnut1 »
Quick look at the ports, balance intake flow vs. exhaust flow. I do think the exhaust duration was excessive for a good flowing exhaust port. Thanks, Charlie
CGT
Post by CGT »
Gotcha, Im not sure if Randy posted the exhaust flowz on the new heads. The new heads do have 52 degree Ex seats. The difference between the exhaust lobes fades pretty fast after about .150 lift or so.
The Comp ex lobe is definitely more aggressive off the seat. The comp intake lobe is definitely meaner than the Bullet for sure also. . There just aren't a huge selection of 230ish .400 lobe lift hyd roller lobes to choose from any supplier.
Warp Speed
Post by Warp Speed »
I like the comp intake lobe and the bullet exhaust lobe on a 108, in at 107ish! LOL 8)
