chevy 406
Re: chevy 406
What does your 406 run? Sorry, i must have overlooked this question. Well, over 10 years ago when I had my 12 to 1 408 in a 3200lb street car it went 6.60s at 109 mph. That was with a turbo 350 trans on street tires. The same combination in a 2800lb bracket car ran 5.80s at 115mph.
Re: chevy 406
B.S.? I hate to read that you feel that way. It's definitely not b.s. The truth is that the 6.60s were on a 275 60 bfg radial t/a, not drag radials. I didn't want to mention that because it might sound like b.s.
Re: chevy 406
No this is a new build just trying to do what I can I build all my own motors,trans and rear ends in my small home garage. I use to build transmissions for a living now just a hobby now I'm a industrial maintenance technicianfarmengines wrote:What does your 406 run? Sorry, i must have overlooked this question. Well, over 10 years ago when I had my 12 to 1 408 in a 3200lb street car it went 6.60s at 109 mph. That was with a turbo 350 trans on street tires. The same combination in a 2800lb bracket car ran 5.80s at 115mph.
Re: chevy 406
[img]
[/img]I just read that post last night so I responded to it, I thought 408 Nova was asking how well my engine ran with the cam I was referring in this thread so I answered. I'm trying to post a picture of my car. In 2004 I raced it mainly at pier7 dragway in Sallisaw Oklahoma in their radial class. Ran a best of 6.63 at 109 in the 8th with a 1.50 60ft. The car weighed right at 3200lbs with me and two sandbags in the trunck. I built another one with a friend a couple years later, 3050lbs 14 to 1 436 cubic inch with a little better head (Brodix 18x) and a new cam from Harold, 280in. 284ex. on a 106 with his .454 lift series lobe. It went 5.90s at 116 on a drag radial.408 Nova wrote -
"I know "tighter" lobe seperations (104-106) have always been ran better on the dragstrip for me in under 12:1 compression ratios, in 350-434 engines. It didn't matter if it was solid or hydraulic, flat tappets or rollers. What does your 406 run?"
Re: chevy 406
Yes sir, I was asking about your engine combo. Thanks for your reply.farmengines wrote:[img][/img]I just read that post last night so I responded to it, I thought 408 Nova was asking how well my engine ran with the cam I was referring in this thread so I answered. I'm trying to post a picture of my car. In 2004 I raced it mainly at pier7 dragway in Sallisaw Oklahoma in their radial class. Ran a best of 6.63 at 109 in the 8th with a 1.50 60ft. The car weighed right at 3200lbs with me and two sandbags in the trunck. I built another one with a friend a couple years later, 3050lbs 14 to 1 436 cubic inch with a little better head (Brodix 18x) and a new cam from Harold, 280in. 284ex. on a 106 with his .454 lift series lobe. It went 5.90s at 116 on a drag radial.408 Nova wrote -
