piston guy wrote:The E6SE head is "normally " avoided because of it's poor design. GT40 iron or aluminum are a far better choice.
The e6se's port designs are nearly identical to the E7's. And many others from that same era for that matter as Ford apparently didn't like making excessive change from one year to the next. It's the CHAMBER design of the E6's that killed that head(severe shrouding), not so much the ports themselves. As mentioned earlier, Mr Malik will tell you how well they ran on the dirt track stuff after some milling away of those recessed chambers. I've also read where other porters/builders say the same exact thing.
I do completely agree that the 40's work better "out of the box", so to speak.. but would rarely waste my time on anything made of iron these days. Life is just too damned short to run iron heads and flat tappet cams any more.
Personally speaking, I port the hell out of everything and usually prefer a heart or kidney shaped chamber that has enough material to be reshaped and gives better squish(larger dual quench zones) vs an open chamber that gives less latitude for shape and increased compression. Aftermarket stuff follows that same trend for a reason as well. Take about a .100 thou off the E6's and add some porting with around .600" roller cam'd valve lift.. and they'll make plenty of steam. Can't do that to the E7's without sinking the valves to stay out of the seats.
As for the pressed vs floating debate.. it makes no sense to have some guy torching away and beating up your hard earned parts to even consider pressed pins any more. Floating pins wear the bore better and are just SOOOOO much easier to be mocking in and out of an engine during fitting/blueprinting. If it's just stock junk you're tossing together and close enough gets you where you need to be?.. then so be it. Otherwise make life simpler for yourself and run floated.
