NO - but as a special treat the next time I am in your area you can buy me a rum & coke!!!!!!RevTheory wrote:I said I thought he'd at least sneak up on 350 hp. Don't I at least get a ribbon? Probably not...
DV
I'll have the sangria at the ready!David Vizard wrote:NO - but as a special treat the next time I am in your area you can buy me a rum & coke!!!!!!RevTheory wrote:I said I thought he'd at least sneak up on 350 hp. Don't I at least get a ribbon? Probably not...
DV
Ah, but your score was in reference to EMC numbers, while David's was using Terry's dyno, so his score is 358/378 vs. actual 351/366 or off by 19.gvx wrote:if you guess was wayoff 358hp/378tq I would guess I am a big time looser also lolgvx wrote:360 HP/ 372 TQ
Always the bridesmaid and never the brideMadBill wrote:Working from the EMC dyno calibration with which most members are more familiar (thus 362 HP, 375 lb-ft.), the rankings I come up with are:
1st: Casper with 358/375 for 4.
2nd: gvx with 360/372 for a score of 5.
3rd: tie between Midnight and Gary, both with 365/380, for scores of 8.
5th: psy with 375/375 for a score of 13.
Given the slightly vague terms of the original challenge, I think the stand-up move for David is to award both Walter and Casper autographed copies of his book!
Well done all!
Do you have any height limit in mind ... 1/2" or 1" or 2" ?David Vizard wrote:Well it seems we are not done yet with this 306. The next engine to go on the dyno was late so one more test is being done and it's a real quicky. Terry is going to try some spacers.
We have had the Performer manifolds respond to more plenum but that was on engines with more power. Still it'as worth a try here so lets see what it does.
DV
I have rarely found times when a spacer was NOT worth some torque or horsepower or both.David Vizard wrote:Walter,
Thanks for the spacer info here. I passed this on to Terry and he said he would round up whatever he could for a test this coming Friday (tomorrow). If we fail at that do you have any more specific info that I could use in my book as this looks like it could be 'easy power' if the appropriate spacer was selected.
DV
That pretty much explains the Jomar "Equalizer" spacer.DaveMcLain wrote:I have one that sometimes can work well on a dual plane. The spacer started out as a 1 inch four hole but it is now a three hole with one side is cut out into an oval. I put it on the intake with the two hole side over the deep plane and the oval hole over the top plane. I've seen it be quite good once in a while especially if the intake is a really low one and the carburetor isn't particularly great.
