sbc 383 intake recommendation
smokie
Post by smokie »
victor jr
team G
Strip Dominator
performer rpm
holley 300-36
383
dart pro 1 heads
11-1
244-248 hydraulic roller
3,500 stall
th400
3.73 geared g body
street/strip
will any of the three have an advantage over the others? i'm leaning towards the team G or holley Strip Dominator.
racear2865
Re: sbc 383 intake recommendation
Post by racear2865 »
300-25
reed
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
With stock, out of the box intakes, there is VERY little difference
JOE SHERMAN RACING
user-612937456
Post by user-612937456 »
bigjoe1 wrote:With stock, out of the box intakes, there is VERY little difference
JOE SHERMAN RACING
Exactly what I was thinking maybe 5 hp difference in extreme cases never know the difference except with dyno comparison
SchmidtMotorWorks
Vendor
Post by SchmidtMotorWorks »
Biteme
Post by Biteme »
Any of the top 3
Zmechanic
Post by Zmechanic »
Do you have hood height clearance constraints? Those manifolds are definitely not all the same height, and have somewhat different plenum volumes to go along with it.
smokie
Post by smokie »
no hood clearance issues.
hereinmissoula
Post by hereinmissoula »
Not an expert but I would think AirGap be best. 3.73's, only 3500 stall. And only 383 . Curious as to others opinions. Your cam right on the line for needing a single in my opinion.
That cam on a 106lsa with Airgap would rock in my opinion.
smokie
Post by smokie »
the cam is on a 110.
Biteme
Post by Biteme »
What size are the heads?
If they're 180 or 200cc I'd use the team g or Vic jnr.
Bigger than that I'd use the strip dominator.
Duel planes manifold belong on taxis and tow cars.
ijames
Post by ijames »
JOE SHERMAN RACING
Which one would be best if fully ported? If they are equal out of the box, might as well buy the one that has the most future potential.
Biteme
Post by Biteme »
Strip dominator.
Another good one is the edelbrock 2925.
There's is a difference between these bigger intakes and the smaller Vic jnr and team g. But on a 500hp motor it'd only be 10-15hp.
hardatach
Post by hardatach »
If you have plenty of hood clearance.....you might look at one of the new Sniper Intakes from Edlebrock.
MT Jeff
Post by MT Jeff »
The Strip dominator is a proven piece and it cost less than some of the others. Use the money towards a good adjustable carb and an a/f meter. If you ever thought about spaying it a single plane would be better. IMO.
I might think a street tunnel ram but that's me. They just look mean. Not that you need it. But you said height isn't an issue.
Your kinda on the line with those heads and cam (bracket race) and gears and converter (more street) sounds like a fun ride though.
The air gap would get the job done with more low end on the street with a spacer maybe for some top end.
Will it be more street or race?
Why is the least trained, lowest paid tech working on the most important part of your car, THE BRAKES ! I know I work next to him.
