Truckedup wrote:I believe this is a Fiat Firefly head... Looks like a Poly head mated with an LS Chevy head....I assume the head is a compromise of power, fuel mileage and low emissions...
More info:
https://www.allpar.com/forums/threads/n ... es.165833/
In one of the pics, you can see right out through the intake port. The short side of the intake port is pretty straight. That plus the offset valve arrangement looks like they are aiming for high swirl.
I am thinking that someone at Fiat established (correctly) that the intake ports on the existing 1.4 FIRE (4-valve pentroof) were too big. My rough calcs suggest that an engine of this size (333cc per cylinder) and RPM (peak power around 6000 rpm) should have intake ports around 26mm in diameter. That's pretty easy to do with a 2-valve configuration with a bore size of 70mm.
I like the long intake runners, too. And the variable valve timing that shifts intake and exhaust timing together.
This certainly won't be a high-performance engine, but it does look like a good example of keep-it-simple economical design.
