Carnut1 wrote:If there was anywhere this would be beneficial a high speed ssr comes to mind. If surface texture would help the air stay attached at higher speed before separation that would make a ssr that is shape challenged perform better.
condition
If you "trip" the boundary layer to a turbulent condition-just the boundary layer- it enhances the Coanda effect, i.e. aids attachment. That's what the little projections on plane wings do. A rough texture could do much the same thing.
Would be neat to see how that works out on Chads wetflow bench. I mean we pay attention to the texture in the port and the finish dry, what does it flow like with fuel on the walls?
He had an article in a mag that showed the dyno and/or the ET was a lot better with the textured or rough burr finish.
The flow bench never showed any better numbers. (and maybe less?)
So if racing flow benches smooth may be where it's at?
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
All the write ups I have seen on this subject says that it hurts flow but helps power. Another less talked about approach is called ribblets (comes from sail boat design)...Using a 40 grit piece of adhesive sand paper and your finger sanding in the direction of flow on any radius's.
John Wallace wrote:Maybe Larry Meaux will chime in?
MadBill wrote:Be interesting to compare power effects on a gaseous fueled engine.
The only way to know would be ABA dyno testing. Don Terrell the owner of this site wrote a NASCAR Engine book claiming ribletts were worth 10 horse, I have been told by others that that is correct but I have not tested it.
Paper on riblets for sail boats http://rsta.royalsocietypublishing.org/ ... 2.full.pdf
I have to question the little " tricks" people do to get the last little bit of flow. If a port is sized correctly, and has a good shape to it if you cut a little bit here and gain 5 cfm or use a super trick valve job to gain flow, has there been back to back dyno tests to prove that equates into real gain? I guess nascar and prostock is the proving grounds for this were a couple hundredths of et or tenths of a mph matter. Not just surface finish but like adding a wing in a port to get rid of turbulence, Is there enough time in a thousandth of a second the valve is open and closed for turbulence to develop? This is probably a debate all to itself...
