Rember the intake port texture debates?
Frankshaft
Re: Rember the intake port texture debates?
Post by Frankshaft » Tue Jul 25, 2017 9:21 am
From 3 years ago. Ford motorsports super cobra jet heads. These made a 1020hp, with a 2.25 intake. And, only 380cfm.
That's my aggressive cuttered finish.
Frankshaft
Post by Frankshaft » Tue Jul 25, 2017 9:26 am
This is the finish I use if the guy isn't on board with the aggressive cuttered finish. Mildly ported dart pro 1 345 BBC heads.
nickpohlaandp
Post by nickpohlaandp » Tue Jul 25, 2017 9:54 am
Frankshaft wrote:This is the finish I use if the guy isn't on board with the aggressive cuttered finish. Mildly ported dart pro 1 345 BBC heads.
Without me going back and re-reading 14 pages of this thread, does anyone care to share how to create these textured finishes on iron or aluminum (I imagine aluminum would be easier)? Thanks.
swampbuggy
Post by swampbuggy » Tue Jul 25, 2017 10:18 am
Here is a question directed at *----------* i see you thinned down the divider between the runners quite a bit, there has been a lot of talk about that not being a good idea. I have noticed upon close observation that some of Edelbrocks intake manifolds such as the Victor Glidden #2858 and the B.B.C. #2896 Super Victor are cast with quite thin dividers. Your comments would be appreciated much. Thanks Mark.
Frankshaft
Post by Frankshaft » Tue Jul 25, 2017 10:20 am
*'s the only one that knows anything? Those runners are like that otb. Its for area. If it needs the area, that's what you end up with. That's it.
swampbuggy
Post by swampbuggy » Tue Jul 25, 2017 3:24 pm
Frankshaft, I know d_ _ n well * is not the only person who knows how to modify an intake manifold and make horsepower. The reason i directed the question to him is BECAUSE it is HIS manifold, and what do you mean by the letters otb, i am not a youngster who knows all the abbreviations. Mark
nickpohlaandp
Post by nickpohlaandp » Tue Jul 25, 2017 4:09 pm
maxracesoftware wrote:...then i take that same Burr and try to chip the new teeth just right to get the finish i need
Ummm, how do you go about chipping the teeth on the burr?
Ron E
Post by Ron E » Tue Jul 25, 2017 4:16 pm
swampbuggy wrote:Frankshaft, I know d_ _ n well * is not the only person who knows how to modify an intake manifold and make horsepower. The reason i directed the question to him is BECAUSE it is HIS manifold, and what do you mean by the letters otb, i am not a youngster who knows all the abbreviations. Mark
otb= out of the box
GARY C
Post by GARY C » Tue Jul 25, 2017 4:39 pm
otb= out of the box
Yes!... here is a good picture of as cast or OTB divider thickness.
RevTheory
Post by RevTheory » Tue Jul 25, 2017 6:19 pm
If this was asked already, I missed it and apologize: Has anyone done an A-B dyno test between a CNC port and a textured port?
GARY C
Post by GARY C » Tue Jul 25, 2017 7:42 pm
RevTheory wrote:If this was asked already, I missed it and apologize: Has anyone done an A-B dyno test between a CNC port and a textured port?
I haven't seen that question but I would like to see that test.
swampbuggy
Post by swampbuggy » Tue Jul 25, 2017 9:08 pm
Thanks Ron E and Gary C i appreciate the text as well as the pictures, it is all cleared up now! Mark H. And thanks to ALL of you folks for your willingness to share unselfishly what you have learned over time.
nickpohlaandp
Post by nickpohlaandp » Wed Jul 26, 2017 10:40 am
swampbuggy wrote:...And thanks to ALL of you folks for your willingness to share unselfishly what you have learned over time.
I agree wholeheartedly. That's why a lot of us join these forums. I know that's why I joined. That's also why I read pretty much nothing but technical books. I'm constantly trying to read. Now if only I had the $ to experiment with everything I learn... wouldn't life be grand! :D
BradH
Post by BradH » Fri Jul 28, 2017 12:50 pm
Dwayne Porter, the owner of the shop with whom I work closely on my cylinder heads, dyno testing, etc., doesn't have a current SpeedTalk account, but passed on a few questions after reading through this thread. I've tried to take them pretty much verbatim, with some verbiage tweaks of my own:
1. Since there seems to be some pretty specific info on what the "correct" texture is, how critical is the textured finish for power gains to be seen over the typical sanding roll finish?
2. If the ports are left with the typical carbide cuttered finish they would normally have prior to getting hit with a sanding roll, would that be expected to show a power gain over the sand roll finish? I.e, how much is from simply having "texture", and how much of it is having a specific texture?
3. There is a lot of talk about how it works because the texture increases fuel atomization, less fuel clinging to the walls, etc. So how does that part of it figure into using the cuttered finish in the exhaust ports, which I would think "should" be all dry flow?
4. Last comment... seems like that rough chamber finish would just end up being a carbon magnet in long term use.
Me (the OP) again. I posted a pic in this thread on May 25, 2017 2:35 pm of a cuttered port finish that I did. Still curious if "those in the know" think that level of surface texture would be expected to show the benefits being talked about. It seems to fit w/ the nature of Dwayne's questions above. Thanks - Brad
BradH
Post by BradH » Fri Jul 28, 2017 4:00 pm
Uhhh... after re-reading his PM, I think Dwayne intended for #1 & #2 to be ONE question, only with additional context. I interpreted it as two, so feel free to "mentally merge" them together if it makes more sense that way.
