355 camshaft hydraulic roller recommendation
Re: 355 camshaft hydraulic roller recommendation
The nice thing about that trans is the .67 OD really tames down 4.30 gears for street.
Thanks for the input. I was concerned on being able to make any power with a smaller camshaft. The engine has been on a stand for many years waiting to be used again. 20 years ago it had a 537/557 @.050 256/264 flat tappet. Transmission Specialties Super 8 converter with 4.10. it ran great and pulled hard to 7200.
If this is a game here is my speculation (BTW what does the winner get?) 222/226 @.050 108 lsa, .550 lift (on the mild side) Still make the mid 400 HP range plus a wider flatter torque curve. Cam king is right down the middle and Cam king grind @ 108 lsa to make it a little higher peak. More lift if the heads have been ported to flow at a higher lift.
Another question then. What can I get away with and run the power brakes on the street? I haven't bought a converter yet. Not really interested in turning above 6200. Thanks for everyone's thoughts.
- af2
Get rid of the power brakes would be my first off the list.wilson1970 wrote:Another question then. What can I get away with and run the power brakes on the street? I haven't bought a converter yet. Not really interested in turning above 6200. Thanks for everyone's thoughts.
GURU is only a name.
You can't go wrong if you call Mike Jones, mentioned the vacuum requirement and a order the cam from him.wilson1970 wrote:Another question then. What can I get away with and run the power brakes on the street? I haven't bought a converter yet. Not really interested in turning above 6200. Thanks for everyone's thoughts.
i have an 87 mcss with the small 9" dual diaphram booster, and with a vac resevoir can added in line my engines 7" of vac is more than plenty for the brakes.wilson1970 wrote:Another question then. What can I get away with and run the power brakes on the street? I haven't bought a converter yet. Not really interested in turning above 6200. Thanks for everyone's thoughts.
There,...there Chad.CGT wrote:Nobody cares about that damn thing!randy331 wrote:Here's a thread about a 357, hyd roller and a lot of cam talk in it.
May be of interest,..... or confusing.
viewtopic.php?f=1&t=44801
I care.
I been caring for your new heads quite a bit in the past few weeks.
True, I know you have a ton of time in them. I wasn't including you in the "don't give a damn" segment
When choosing a camshaft should you match lift to the maximum flow of the cylinder head?
Does this mean you should match your duration @.050 to the ratio of time your foot contact's the gas pedal while the engine is running?wilson1970 wrote:When choosing a camshaft should you match lift to the maximum flow of the cylinder head?
No.wilson1970 wrote:When choosing a camshaft should you match lift to the maximum flow of the cylinder head?
There's is no relationship between the lift required for a specific application, and the max flow point of the port.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
