AMC 327 - 443 CID Rambler V8
amcenthusiast
Re: AMC 327 - 443 CID Rambler V8
Post by amcenthusiast » Tue Jun 27, 2017 10:08 pm
I could write a small book on Rambler V8 exhaust ports but I think 50% of forum participants are turned off by reading long explanations.
If anyone here could drive this car, I think they'd know why there are no excuses needed for this engine.
Since '56-'65 Rambler V8 heads are a close copy of '53-'62 Cadillac V8 heads & Cadillac made a 429 version of their engine, I think these ported heads get the job done on this 443 RV8 example.
Here's my ported '64 RV8 heads for this 443 engine.
[img]
[/img]
Last edited by amcenthusiast on Tue Jun 27, 2017 10:31 pm, edited 1 time in total.
XRV8 Race Parts > for AM's '56-'67 Rambler V8: http://amcramblermarlin.1colony.com/favorite_links.html
amcenthusiast
Post by amcenthusiast » Tue Jun 27, 2017 10:14 pm
Showing ported '64 AM RV8 siamesed center port, from outlet side, currently in use on this 443 engine:
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Tue Jun 27, 2017 10:18 pm
Showing other end port, ported, '64 Rambler V8 head, currently in use on 443 stroker block:
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Tue Jun 27, 2017 10:27 pm
Shop drawing with some illustration for explanation:
-since hot air flows faster than cold, the exposed roof in section 3, having water jacket underneath, is designed to increase scavenging. (red line/no water jacket, blue line/water cooled exhaust vapor)
The 'loudspeaker shape' of the port's midsection gives these engines their distinctive signature sound. (section 2)
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Wed Jun 28, 2017 1:11 am
Same ports, in sequence, confessing much work done to enlarge the valve pocket outlet area:
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Wed Jun 28, 2017 1:15 am
2nd head, in sequence, confessing much work done to enlarge valve pocket outlet area:
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Wed Jun 28, 2017 6:57 am
Ported '64 heads for 443 CID Rambler V8, showing unfinished exhaust port outlets having gouges from 'leaning on it', caused by rubbing shaft of porting tool, in order to spend time 'going around the corner' to enlarge the valve pocket outlet area deep inside the 'long and curvy' port:
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Wed Jun 28, 2017 7:05 am
Ported '64 Rambler V8 heads for 443 CID Rambler V8, 2nd head, unfinished outlets showing gouges caused by rubbing the shaft of the porting tool in order to 'go around the corner', to enlarge the valve pocket outlet area:
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Wed Jun 28, 2017 7:51 am
Exhaust port outlets gouged by porting effort, caused by rubbing long shaft 'to go around the corner' (shown by shop drawing):
Showing DIY brazing pit used to repair exhaust port outlet shape, also to fill void in center port roof after removing 'top bolt hump':
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Wed Jun 28, 2017 7:56 am
'64 Rambler V8 heads for 443 stroker, fully ported exhaust ports, gouged outlet repair; post brazing, pre-finishing:
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Wed Jun 28, 2017 8:29 am
'64 AMC 327 heads reworked for 443 stroker application; showing post-brazing, center port top bolt hump elimination plug void filled and ground smooth:
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Wed Jun 28, 2017 9:04 am
AMC 327, '64 head, exhaust port rework for 443 stroker application; brazed outlet repairs getting ground flush:
[img]
[/img]
Second head:
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Wed Jun 28, 2017 9:08 am
AMC 327 XRV8 Race Parts, exhaust ports reworked for 443 stroker, finished:
[img]
[/img]
Second head:
[img]
[/img]
amcenthusiast
Post by amcenthusiast » Wed Jun 28, 2017 9:13 am
Next, showing pics of intake ports...
amcenthusiast
Post by amcenthusiast » Wed Jun 28, 2017 8:35 pm
'64 AM RV8 intake ports; stock vs ported for 443 stroker:
[img]
[/img]
