I couldn't agree with you more on this. I have been in the cooling/radiator business since 1981. This is number 2 out of 2 vehicles over the years that I am not figuring out what the problem is. The other was a blown 57 chevy, 540 Merlin w/Mooney Ham 12:71 and customer would not allow pulling the cylinder heads and he instead sold the car out of state.I post this from time to time, but I'm not sure anyone wants to listen...
With cooling systems. People start guessing and start changing things. Some time you hit it, some times you don't. Guesswork gets expensive and time consuming. I can't guess any better than anyone else
There is some science to diagnose cooling system problems.
IR guns are pretty useless on this car. You can't get a good reading through the grill ( 41 Willys w/oe style grille, chrome bars about 1/2" apart ), can't remove the grill with out draining system, moving wiring harnesses, removing the radiator/shroud/fan/overflow reservoir assembly as the lower radiator support has an integral air dam so cant get to the bolts ). IR guns are liars on shiny or even dull aluminum surfaces and even black hoses are considerably off on most IR guns. This car is PACKED under the hood so radiant heat from headers, engine block, etc interrupts good temp readings. If fan is on, it throws so much hot air that surface temp readings are not trustworthy either.Start with checking temps in at least four spots. I prefer to use thermistor probes into the coolant, an IR gun can be used to an extent.
Placing probes is not an easy endeavor either. Would have to remove the radiator, drill more holes and tig weld in more npt fittings, buy 3 more gauges to go with the one Autometer manual gauge ( $140 a pop for full sweep ) that I do have. ( don't trust electric gauges for serious diagnostics and don't trust "cheap" manual gauges as I have seen way too many variances in cheap gauges over the years. Gauge in the dash on this car is off 15 degrees or more past 190F and this is a new electric gauge that was in the car when it came to me ).Place probes, take reading in at least four spots.
Radiator inlet and outlet. Before the thermostat and after the water pump.
Agree 100% with this.A good working cooling system will have a 12-15 degree delta T. ( across the radiator in and out, and also engine in and out )
Agree, however, if cooling system capacity is insufficient because of a mechanical problem such as the head gaskets being wrong for the cylinder head/block combo, the car might require a larger cooling package than can be installed which is really what I am beginning to question.Watch the reading as the engine is running and cooling system is working.
Temps Closer together than that indicate a cooling Capacity problem. (Insufficient cooling)
Temps Farther apart indicate a coolant Flow problem. (Restriction of coolant flow)
Closer = Capacity. Farther = Flow
.For example, If a capacity problem look at airflow and radiator size/capacity
If a flow problem look for plugged (internally)radiator, water pump issue, thermostat, collapsing hose, other flow issue
Shouldn't be a flow problem. Pump seems to move plenty of water, radiator is new ( I welded the tanks onto the core ) so I know there is no restriction there. Hoses are now 1 3/4" in & out including an upper water neck that is 1 3/4" in & out.
There is physically no more room available on the Willy's coupe without cutting frame horns off of a very pretty, powder coated gray metallic tube chassis and also cutting out inner fiberglass fender wells. Unfortunately, this is not my car or that would probably happen.
I feel I have a pretty firm grasp of what it takes to cool a properly running and properly designed engine and that's why I am here asking other now. Wow! I know, right?
If having trouble finding a flow problem, pressure gauges can help locate the restriction.
For the OP, ( and. Not criticizing) if you did this, you would be able to find out if you had to rework the radiator or airflow before you went ahead and did.
I appreciate your input and wisdom on this very much. If you or anyone else has any other thoughts I am all ears. I am going to roll a little more timing into the motor tomorrow morning and put a 140 amp alternator on to replace the 90 amp alternator, just for peace of mind, since the fan is pretty hungry on top of Meziere, HVAC blower motor, ac compressor and E-fuel pump just to take that out of the equation.
Again, any other thoughts and I am all ears, always!
Thanks,
Scott
