lifter angle
lifter angle
can changing lifter bore angle in and engine make more power has any body done this thanks
Re: lifter angle
I don't know if this helps but some years back i used S&S off center lifter blocks in an Harley Sportster style engine build , the intent of the offset was to get the lifter roller away from the cams center line and offset towards the cam lift face , this was to relieve some of the side thrust in the lifter bore that was generated with very aggressive lift profiles, cam timing had to be corrected to suit, so the use of Red Shift cams without the lobes welded in place were used ,once indexed the lobe was then welded to the core.
This also had the benefit of setting the cam timing true to each cylinders actual individual timing points ,negating the stack up of error that occurs with gears ,drives ,key ways ,alignments etc.
Re: lifter angle
most lifter bore angles are used to get a straighter sight line for the push rod to the rocker arm like a BBC
Re: lifter angle
Tell that to the SB Mopar about push rod angles!
Re: lifter angle
There is a difference between an off-set lifter and physically changing the lifter bore angle. Changing the lifter bore angle will also require an expensive custom camshaft based on the new angle.
Re: lifter angle
Especially when trying to run a hydraulic roller with tall lifters. Been there and I believe it was a suburb of hell.mag2555 wrote:Tell that to the SB Mopar about push rod angles!
Re: lifter angle
Oldsmobile had "39 degree" and "45 degree" lifter banks, depending on year and application. I don't know of any performance gain of one angle over the other.
I can absolutely guarantee that if you have the wrong camshaft for the application, you'll have a non-tuneable POS.
Re: lifter angle
Changing the angle itself won't add any power however, what that angle change does to the rest of the valve train can certainly be the cause of producing more power.redgoldstein wrote:can changing lifter bore angle in and engine make more power has any body done this thanks
