Page 6 of 6
Re: Mid lift rockers
Posted: Thu Nov 02, 2017 7:46 am
by kimosabi
jed wrote: ↑Wed Nov 01, 2017 8:59 pm
Mr Kimosabi I am about to set up T&D rocker arms on a pair of Brodex LS heads. I am perty sure the T&D
Rockers are designed to run on the mid lift theory.
How would you suggest I set them up??
I have no experience with aftermarket shaft or pedestal rockers from the US. Apart from Ford Cologne V6 and a few other European engines with a shaft rocker system from factory, that's it.
Posted: Thu Nov 02, 2017 10:30 am
by Steve.k
Geoff2 wrote: ↑Thu Nov 02, 2017 4:58 am
Agree, use steel for rocker arms. Why take a chance?
Steel rockers are definitely tough but the old prostock boys ran crane golds for years to 10,000 rpm. I recently had a failure on a crane gold that im guessing had well over 10years on them. So not bad service. I ordered the new crane wide bodies as when i talked to crane the rep told me the original cranes were designed for 700lbs spring pressure and the new wide bodies 900lbs. I am running 680 open pressure so right on edge for old rockers, older used rockers would've felt the strain. I assume the p/s boys years ago ran alot higher pressure.
Posted: Thu Nov 02, 2017 9:00 pm
by racear2865
Where is Warp when you need him?? and I bet it aint aluminumum
reed
Posted: Fri Nov 03, 2017 2:34 pm
by turdwilly
racear2865 wrote: ↑Thu Nov 02, 2017 9:00 pm
reed
You're correct - the rockers he uses are not aluminum - they are unobtainium.
