Page 1 of 1
Aston Martin Engine
Posted: Fri Sep 15, 2017 7:56 pm
by ProPower engines
hey guys
I have a customer that has a 1974 Aston Martin with a four cam V-8 engine and I am trying to ID it before we get much further.
On the Valve covers it has Aston Martin Lagonda in raised letters. Again this is a 4 cam V-8 engine.
It uses 4 Weber carbs for induction.
It has sat for some time and ran fine for a short time but developed some running issues soon after coming out of storage and has a couple very low holes where the heads need to come off but before I tear in apart I am looking for some details as to what engine it really is.
Any help will be greatly appreciated
Dave
Re: Aston Martin Engine
Posted: Fri Sep 15, 2017 8:30 pm
by Newold1
Posted: Fri Sep 15, 2017 9:59 pm
by ProPower engines
I am told it is a series 3 engine.
I will look at the link
Posted: Mon Sep 18, 2017 10:59 am
by David Vizard
ProPower engines wrote:hey guys
Dave
Dave,
This sounds like the Callaway headed engine.
DV
Posted: Fri Sep 22, 2017 12:37 pm
by lewy-d
I think this would be the Tadek Marek engine. Basically the same V8 engine Aston used FOREVER (with the exception of the callaway)
Posted: Tue Oct 03, 2017 6:16 pm
by enigma57
Dave, I have some info from the Aston tech manual for 1974. Mainly regarding the Weber carb setup and differences in UK spec and US spec as to jetting, etc.
If you have a 1974 series 3 Lagonda engine, it will be a 325 cu. in. quad cam engine putting out a bit over 300 HP and have 4 Weber 42 DCNF carbs......
http://driving.ca/aston-martin/auto-new ... r-34-years
...... Unless it has been upgraded to Vantage spec and in that case, it will have 4 Weber 48 IDF carbs, a bit more compression and different cams. I believe this performance package is called the 580 X-Pack engine (Works Service Conversion).
The 580 X-Pack engine is fitted with four Weber 48 1DF3/150 carburetors and a ZF 5-speed manual gearbox (Euro-spec). Cranks out 432 hp @ 6,200 rpm with 536 Nm of peak torque @ 5,100 rpm. Longitudinal acceleration is rated as: 0-60 mph in 5.2 seconds, 0-100 mph in 11.5 seconds, 0-120 mph in 17.1 seconds, and 0-150 mph in 37.7 seconds. It does the ¼ mile @ 108 mph in 13.3 seconds. Its top speed is a respectable 163 mph.
Best regards,
Harry
