Let me guess - Yamaha?Schurkey wrote:I bought a new-to-me motorcycle a few weeks ago. Learned while looking through the manual that there's no oil pressure gauge or light. There is an oil-level warning light.Crazy.
Every Yamaha that I've owned or worked on has been like that - it appears to be their standard practice. There are pluses and minuses to it. On the one hand, the usual failure mode of the owner failing to ever check the oil level gets caught before it goes catastrophic. On the other hand, other failure modes of someone forgetting to tighten the oil filter, breakage of the oil pump drive chain (some of them use a scary thin chain to drive the oil pump), or worn bearings doesn't give any indication before disaster.
My little Honda 125 has no oil warning whatsoever. No level, no pressure. It uses a rolling-element bottom end. There is an oil pump, but it is only a circulating pump, it doesn't develop appreciable pressure.
