8.1 inch rod in stock block/stroke 350 and -----
David Vizard
Re: 8.1 inch rod in stock block/stroke 350 and -----
Post by David Vizard » Sat Sep 23, 2017 7:31 pm
gowest wrote:This is sounding like a dynamic flow bench !
No - you have only 300 guesses left.
DV
David Vizard
Post by David Vizard » Sat Sep 23, 2017 7:39 pm
PackardV8 wrote:Interesting math; check me here, but an 8.1" rod and 1.74" of stroke = 9.84"; can't stay under a 9.025" OEM SBC block deck, so that's already .815" out of the deck before we consider the piston and rings?
EXACTLY RIGHT JACK BUT HOW WILL IT ALL WORK?????
DV
paulzig
Post by paulzig » Sat Sep 23, 2017 8:46 pm
Longer skirt on the piston, drop the rings down and the remaining .820" that pops up past the deck you'll shape to mirror the combustion chamber shape... ??
What are you making a diesel?
David Vizard
Post by David Vizard » Sat Sep 23, 2017 8:48 pm
paulzig wrote:Longer skirt on the piston, drop the rings down and the remaining .820" that pops up past the deck you'll shape to mirror the combustion chamber shape... ??
NO & NO
DV
travis
Post by travis » Sat Sep 23, 2017 9:09 pm
I'm guessing not a conventional cylinder head? Or some sort of spacer between the block and head? Otherwise I don't see it being physically possible. I haven't done the math but I don't think you could physically offset the pins far enough to fit this all together.
David Vizard
Post by David Vizard » Sat Sep 23, 2017 9:14 pm
travis wrote:I'm guessing not a conventional cylinder head? Or some sort of spacer between the block and head? Otherwise I don't see it being physically possible. I haven't done the math but I don't think you could physically offset the pins far enough to fit this all together.
Part right and part wrong but some good deductions all the same.
DV
cgarb
Post by cgarb » Sun Sep 24, 2017 12:12 am
This is going to sound weird, but are you making a compressor of some sort? I've heard of people using Volkswagen engines and having them run off 2 cylinders and compress air with the other 2.
RCJ
Post by RCJ » Sun Sep 24, 2017 6:07 am
Wrist pin is offset to fit in to the deepest part of combustion chamber.
John Wallace
Post by John Wallace » Sun Sep 24, 2017 6:42 am
Using a conventional crank?
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
ptuomov
Post by ptuomov » Sun Sep 24, 2017 8:37 am
Sounds like some kind of spacer would be needed to move the crankshaft centerline down, unless the engine is destroked dramatically.
David Vizard
Post by David Vizard » Sun Sep 24, 2017 11:01 am
cgarb wrote:This is going to sound weird, but are you making a compressor of some sort? I've heard of people using Volkswagen engines and having them run off 2 cylinders and compress air with the other 2.
That is a great idea -wish I had thought of that when I could not afford the outrageous cost of compressors in 1970's UK.
DV
David Vizard
Post by David Vizard » Sun Sep 24, 2017 11:02 am
ptuomov wrote:Sounds like some kind of spacer would be needed to move the crankshaft centerline down, unless the engine is destroked dramatically.
stock 350 stroke and crank location
DV
David Vizard
John Wallace wrote:Using a conventional crank?
stock cast 350 crank
DV
ptuomov
Post by ptuomov » Sun Sep 24, 2017 11:22 am
stock 350 stroke and crank location DV
So is this a piston design with rings below the pin? The wrist pin would have to be inside the dome somehow and rings below the pin.
David Vizard
Post by David Vizard » Sun Sep 24, 2017 11:56 am
Well you and a couple of other posters are definetly moving in the right direction.
DV
