A different type of solid roller lifter.
Post by pdq67 » Thu Sep 28, 2017 11:35 am
Didn't somebody a while back try to make solid roller lifters where the, "solid roller", rolled in a nest in the bottom of the lifter body on a film of pressure-fed oil like the mains and rods do??
If so, did anything come of this?
pamotorman
Re: A different type of solid roller lifter.
Post by pamotorman » Thu Sep 28, 2017 1:27 pm
I believe this is what you are referring to. Shubert Lifters
GuysMonteSS
Post by GuysMonteSS » Thu Sep 28, 2017 4:14 pm
That was Schubeck,not Shubert.
As in Joe Schubeck,or as he was also known,"Gentleman Joe",from his drag racing days.
http://schubeckracing.com/history/
I was very interested in his "Roller X" Lifters and had even paid for a set for my BBC.
It was poor timing as right at the same time,IIRC,his money partner pulled the plug on further production.
So I never did get to try what,in theory,seemed like the final answer to bulletproof solid roller lifters.
Guy
'86 Monte SS,513 BBC,AFR heads,Bullet solid roller cam,Doug Nash 4+1 5 speed,Hurst Inline Shifter,Ford 9 inch Rearend.
CamKing
Post by CamKing » Fri Sep 29, 2017 12:09 pm
I don't think any other lifters, in the history of lifters, destroyed as many engines as the Schubeck lifters.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
lewy-d
Post by lewy-d » Fri Sep 29, 2017 12:14 pm
the roller "X" lifter looks like an exact copy of a Land Rover 2.0 or 2.25 liter lifter. which I usually think of as being an agricultural engine.
I'm no good at posting pictures, so maybe someone else can. The Land Rover part number is RTC6564. I don't know if lifter weight is a important
issue, but the Land Rover parts are lunkers!
tt 383
Post by tt 383 » Fri Sep 29, 2017 1:00 pm
Weren't their some "no lash" ceramic faced solids or some bs?
englertracing
Post by englertracing » Fri Sep 29, 2017 3:10 pm
Post by pdq67 » Sat Sep 30, 2017 6:52 pm
OK1
Anything wrong with that lifter design?
Run, "tight-lash", and go..
peejay
Post by peejay » Sat Sep 30, 2017 7:32 pm
Wow, that looks like a bad idea!
Almost as bad as the round nosed "slider" lifters - no rolling element at all!
Post by pdq67 » Sat Sep 30, 2017 8:28 pm
Isn't the concept of it rolling on a thin film of oil like the main and rod bearings do?
The Radius Kid
Post by The Radius Kid » Sat Sep 30, 2017 8:39 pm
Sort of.
Your bearings encapsulate the journals.
That only rides on one side.
Then there's the ceramic (IIRC) aspect.
Ceramics tend to be brittle as well as hard.
Post by MadBill » Sat Sep 30, 2017 9:06 pm
Yes, rod and main bearings operate on the hydrodynamic wedge principle, which requires a closed and restricted oil circuit. Imagine how well a rod bearing would hold up with 0.020" clearance and a drip feed of oil...
Post by pdq67 » Sat Sep 30, 2017 9:45 pm
OK then, how about DLC coated tool-steel lifters with the foot of the lifter as a nest that covers about 48 percent of the roller, again, DLC, on top and on each side within say .005" or so, then run the lash at something like .004" or so hot.
Can't cover over 50 percent because then you couldn't get the roller in the foot's nest! Otherwise, make the nest part of the lifter so that it would be a separate piece so the roller could be covered by say 80 percent, then screw the lifter nest and roller onto the foot of the lifter.
And then fully pressurize the lifters, (and small oil feed holes), just like the mains and rods.
We would have to run a trial to see how big the bleed holes would have to be so that enough oil would flow through them to create the hydrodynamic wedge to allow the rollers to rotate. No small job at all as I see it... AND certainly NOT cheap to make, imho!
CharlieB53
Post by CharlieB53 » Sat Sep 30, 2017 10:35 pm
This design still has possibilities.
If the 'cup' was say 60+ % of the roller such that the roller had to be inserted from one side, the other side having a 'lip' so the roller could not escape, then another 'lip' placed on the insertion side, making a 60+% enclosure pressure fed with oil. Thus even if the lifter were to 'float' the roller would still be contained.
Post by pdq67 » Sun Oct 01, 2017 1:52 am
Charlie,
At least you see some possibilities here for this.
Thanks,
