Camshaft Break In
Camshaft Break In
Hello Guys this is my first post, longtime registered lurker just trying to gain some knowledge. Just had an outer spring tested. Result was 80# @ 1.900 and 165# at 1.350. Camshaft is solid flat tappet with .550 lift and 252 degrees @.050. Is this too light for a normal break in procedure ? Thanks in advance.
Re: Camshaft Break In
Thanks Jed for responding, this is my first cam install. I was concerned if open pressure was enough to control the valve train since most of what I've read mentions 100-110+ seat and 200-220+ open. Failed to mention this is a sbc 406 with edm lifters. I will give it a try and pay close attn to rpms, don't want lifters bouncing off camshaft. Again Thanks
